1. jackadillo's Avatar
    I wasn't able to properly root my Nexus 4 while using this guide. I wound up idiotically formatting the wrong part of my phone, so now my phone lacks an OS.
    Is there any way I can access my phone via USB? I'd like to install a stock ROM and start over clean!
    02-23-2014 02:05 AM
  2. UJ95x's Avatar
    You can still recover it by flashing factory images onto the phone.
    Get those from here: https://developers.google.com/android/nexus/images
    Sent from my Galaxy S4 running SlimKat 4.4.2
    02-23-2014 02:24 AM
  3. srkmagnus's Avatar
    After downloading the factory image follow this guide: [GUIDE] Nexus 4 - Factory Image Restore
    02-23-2014 02:32 AM
  4. jackadillo's Avatar
    Can't even mount from recovery to access my phone via USB. Had to go here:
    Nexus Root Toolkit v1.8.0 | WugFresh
    Hoping it works. Downloading the factory image via the toolkit.
    - - - Updated - - -
    Guide definitely looks legit, but I'm a bit unnerved by the OP there not giving specific directories to follow.
    02-23-2014 02:32 AM
  5. UJ95x's Avatar
    - - - Updated - - -
    Wug's toolkit will work if you had USB debugging on or can get into fastboot
    The OP in the guide is a former ambassador here. Definitely legit
    02-23-2014 02:40 AM
  6. jackadillo's Avatar
    Thanks for the guide. The toolkit I linked fixed everything, got me rooted, and has allowed me to flash slimkat.
    02-23-2014 03:12 AM
  7. UJ95x's Avatar
    Awesome. Glad you got it working
    02-23-2014 12:43 PM
  1. Please help!
    By blinkchick765 in forum AT&T Galaxy S III
    Last Post: 03-04-2014, 07:45 PM
  2. Sync desktop email with G2 email
    By Pgreenlie in forum Verizon LG G2
    Last Post: 02-24-2014, 11:25 AM
  3. Scheme I'm using to help Device Manager locate/reset my Note while using PIN numbers
    By thecaptain42 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 02-23-2014, 08:42 AM
  4. Replies: 3
    Last Post: 02-23-2014, 06:21 AM
  5. HELP................
    By Amanda McFeron in forum Samsung Galaxy S4
    Last Post: 02-22-2014, 08:36 PM
