Results 1 to 3 of 3
    ljxdaly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default anyone having trouble with "mediaserver" and battery drain?
    out of the blue, i'm having severe battery drain, but all i'm seeing is "mediaserver" as the culprit. plus, whatever is really working behind the scenes is stopping deep sleep.
    i couldn't pinpoint things, so i did a factory reset. same thing. i know google play services has acted up in the past, so maybe others are experiencing something similar? if so, i'll just wait out the storm. if not, i'll have to figure out which app(s) are rogue.
    DTID likes this.
  2. #2
    DTID's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: anyone having trouble with "mediaserver" and battery drain?
    Quote Originally Posted by ljxdaly View Post
    I have had Google Play Services disabled for ages now. The Power amp app also caused the Media Server drain but if you did a factory reset it can't be that.
    I'd uninstall Google Play Services and try that. Make sure you disable any apps which you don't use / need in the Application part of Settings.
    Sent from my SM-N9005 using Tapatalk
    ljxdaly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey thanks for the reply. It was either play music or play movies. I disabled both and things are fine now. It kind of annoys me cuz I never use those apps. Why they should act up is beyond me.
    Sent from my XT1049 using Tapatalk
    DTID likes this.
  1. Nexus 7: Battery drain and CPU usage bug found in 4.4.2
    By jerrykur in forum Google Nexus 7 Tablet (2013)
    Last Post: 03-21-2014, 01:21 PM
  2. Samsung Galaxy S3 Extended Battery 4800mah
    By JanP7 in forum Samsung Galaxy S3
    Last Post: 03-09-2014, 12:21 AM
  3. Google Hangouts: Google's logic in improving iOS version before Android
    By tdawg00 in forum General News & Discussion
    Last Post: 03-08-2014, 08:07 PM
  4. Replies: 3
    Last Post: 03-08-2014, 12:15 PM
  5. Problems with the screen of my phone
    By Gustopho in forum Verizon Galaxy S3
    Last Post: 03-07-2014, 05:03 PM
