Help me to Unlock Network
samiimran
5
Hi,
I have purchased Samsung galaxy s3 4G LTE in Dubai, everthing is working perfect but my phone has network lock.
Please check the below information:
Network: Verizon
Legal Information
Model number: SCH-I535
Android version: 4.0.4
Baseband Version: I535VRLF2
Kernel Version
3.0.8-618049-user
se.infra@sep-111#1
SMP PREEMPT Fri Jun 15 07:53:02 KST
2012
Build Number: IMM76D.I535VRALF2
Hardware Version:
I535.10
Hope this will help you, and please reply as soon as possible.
Thanks
Sami
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
You have a Verizon s3. With the latest update, the sim slot is unlocked. If you can't get the update directly, then you can root and install 4.3 which should automatically unlock it.
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,370
118
63
I can't remember which version of Android does it either, but since we are already discussing rooting, flashing a custom ROM like Cyanogen or Slim might be just as good of a solution. The updates will continue a lot longer than the official ROMs will.
Golfdriver97
Moderator
Dec 4, 2012
35,370
118
63
Check out galaxys3 root .com and check out the videos there. Follow instructions for the Verizon S3.
From a Liquid Nexus 5
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Either 4.1 or 4.3, can't remember exactly. If you are rooting anyway go with at least 4.3 to be safe
rockpaperreality38
