Results 1 to 13 of 13
    Default Chrome Sync Across Devices Problem
    For the past couple days, I can't see open tabs of other devices in my history page in Chrome desktop. Chrome is up to date on my PC Windows 8 and all of my Android devices. On both of my Android devices, Chrome sync is on but when I go to see other devices, it gives me a message to sign into Chrome on my computer, which I already am. I've signed out and back in several times. I've looked at dashboard and everything looks good. Any ideas on what the issue could be? I'm out of ideas.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,753 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Chrome Sync Across Devices Problem
    Quote Originally Posted by clemson77on View Post
    I had that message for a brief moment, then it showed everything. Are you using Chrome Beta for your devices?
    Quote Originally Posted by Golfdriver97 View Post
    No, just the normal Chrome browser. It almost seems like it's an account problem. I have a Windows 8 PC, a Windows 7 PC, a LG G Pad 8.3, and a HTC One M7. None of them show other device tabs even though they are all signed into and have sync enabled.
  4. #4
    Posts
    Global Posts
    32,753 Global Posts
    Carrier
    Maybe a cache clear?
    Sent from my HTC One_M8 using AC Forums mobile app
    No go. I also just noticed that my Google Drive isn't syncing either.
  6. #6
    Posts
    Global Posts
    32,753 Global Posts
    Carrier
    Out of ideas myself. Sorry.
  7. #7
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Logout of the account from the device then log back in. If there's no improvement then there could be an issue with the network. Just in case, reboot all connected devices.
  8. Thread Author  Thread Author    #8
    Thanks for trying. I just noticed that in my google sync settings, the item "internet" isn't syncing. It says at the bottom that sync is experiencing problems... This is driving me crazy.
  9. #9
    Posts
    Global Posts
    32,753 Global Posts
    Carrier
    That might be why there is issues. Have you forced a sync?
  10. Thread Author  Thread Author    #10
    I've unchecked it and rechecked it, turned sync off and back on. It always gives me an error.
  11. #11
    Hey,
    I have been having the same issue!
    Apparently Google knows about this, and is rolling out a server-side update!
    https://code.google.com/p/chromium/i...tail?id=373424
    "Those tab sync issues are likely caused by a server error we recently discovered. The fix is in the process of rolling out, and when it does that should resolve itself.
    The tab sync issue is unrelated to the bookmarks though"
  12. #12
    Quote Originally Posted by Google4Lifee View Post
    Hey,
    This link goes to a page that doesn't exist "The page you asked for does not exist."
    I've been having the same tab syn issues though, for about a week now.
  13. #13
    Try this link... https://code.google.com/p/chromium/i...tail?id=373424
    When, do you think they will fix this issue. Really annoying.
  1. How do I stop the sync on Whatsapp?
    By amitmalikjaipur in forum General Help and How To
    Last Post: 01-02-2015, 11:19 AM
  2. SG3 Real serious problems
    By Sticky Shrapnel in forum AT&T Galaxy S3
    Last Post: 05-30-2014, 09:52 PM
  3. Google Drive Problems
    By tmann202 in forum Moto X (2013)
    Last Post: 05-16-2014, 12:53 PM
  4. Galaxy s4 problem charging?
    By aidopotato in forum Samsung Galaxy S4
    Last Post: 05-16-2014, 03:38 AM
  5. Google Drive Download Does Not Work On Kit Kat Device
    By FSchmitthammer in forum Android 4.4 KitKat
    Last Post: 05-13-2014, 07:18 PM
