Results 1 to 5 of 5
    Default Note 3 battery
    What's going on, I haven't even used 3d games just the occasional check for messages, some music maybe a video or two in the WHOLE DAY and my battery life suffers a ton, I.e. even when I'm not using it it's being drained. I disconnected it at 7:49 AM and it's a 10:23PM, yeah it's been a while but I be barely used my phone in the whole day and I'm at 3 percent. Click image for larger version.
ID:	119834Click image for larger version.
    Sent from my SM-N900T using Tapatalk
  2. #2
    jpr
    jpr is offline
    jpr's Avatar
    Posts
    Global Posts
    1,702 Global Posts
    Default Re: Note 3 battery
    Install gsam battery app to get a better breakdown of what's using your battery. I'd imagine you have a lot of wakelocks as well which you can see in gsam. You clearly have a lot of stuff running in the background even when the screen is off. You've either got some rogue apps or you have them poorly configured.
    For Google services a lot depends on your app settings and what you are syncing and we don't know what apps or services you use. I don't know what ifunny is but that and hd widgets are using an awful lot of battery for you not using your phone much. You must have a frequent refresh interval for your widgets. If it's adjustable, change it. If it's not I'd uninstall that app.
    Well install gsam and give much more info if you want additional help.
  3. #3
    jeddo45's Avatar
    Posts
    Global Posts
    36 Global Posts
    +1. Wake lock is awesome.
    Brought to you by the Nexus M8
    Thanks
  5. #5
    Also make use of things like greenify if you find out what apps keep waking up your phone.
    Sent from my SM-N900P using Tapatalk
  1. Verizon Galaxy Note 3 Battery Life Poor on KitKat
    By music_man185 in forum Verizon Samsung Galaxy Note 3
    Last Post: 01-13-2015, 01:41 AM
  2. Android System still killing battery
    By Delta Mike in forum AT&T Samsung Galaxy Note 3
    Last Post: 08-09-2014, 07:02 AM
  3. Google map and GPS display problem on Galaxy Note 10.1
    By BillPhillips in forum Samsung Galaxy Note 10.1
    Last Post: 06-09-2014, 11:54 PM
  4. Replies: 22
    Last Post: 06-03-2014, 02:00 PM
  5. GALAXY S3 i9300 (INTL) Battery Charger, Voltage And System Issue
    By Salvator101 in forum Samsung Galaxy S3 I9300
    Last Post: 05-24-2014, 04:27 PM
