Results 1 to 6 of 6
    Default Nexus 4 extreme Lag
    My nexus 4 (using kitkat 4.4.2) from last few month is lagging a lot. The performance of my phone has even degraded in benchmark apps also. The phone remains normally at 38-40c and if wifi or mobile data is used, the temp. reaches 49c.
    I did factory reset 3 times even switched from davlik to art but nothing helps. The lag is so much that I had to uninstall several graphic intensive games.
    And another problem is my phone most of the times charges in usb mode from the wall charger. I have to plug in and out several time to make it charge in ac mode.
    Some of the snapshots are attached with this.
    Please help me !
    Sent from my Nexus 4 using Tapatalk
  2. #2
    Default Re: Nexus 4 extreme Lag
    Welcome to Android Central! Have you tried booting into Safe Mode to see if the lag is still there? If not, then there is probably some app that you keep reinstalling after each reset that is affecting performance.
    https://support.google.com/nexus/answer/2852139?hl=en
  3. #3
    twin100's Avatar
    Posts
    Global Posts
    43 Global Posts
    The tweaks are available within the settings of all recent Android phones in a section called Developer options.
    This section might be hidden on some phones, but its very easy to access. On many phones, you just have to open a certain page in the settings and tap a button seven times. Use Google to figure out how to enable Developer options on your phone if its currently hidden (for example, search enable developer options HTC One).
    Once you have access to Developer options, simply scroll until you find the following three settings, which may be located on the main screen or within an Advanced subsection:
    Window animation scale
    Transition animation scale
    Animator animation scale
    Tapping each of the three aforementioned settings will reveal that its set to 1x by default. If you want to speed up your phone or tablet dramatically, simply change each of those three settings to .5x thats it...restart your device
  4. #4
    xchange's Avatar
    Banned
    Posts
    Global Posts
    478 Global Posts
    Quote Originally Posted by twin100 View Post
    I'm wondering if kitkat did something with the animation times. I've seen this issue as well as this suggestion come up a lot across several forums since 4.4 arrived on more devices
    Changing animation speed is not the solution. My apps, games are lagging, animation speed would just make the fade in fade out effects faster.
    And I am starting to believe that using too much features of developer options affects the hardware performance.
    Quote Originally Posted by B. Diddy View Post
    still lags!
  1. Replies: 4
    Last Post: 09-07-2015, 12:50 PM
  2. Replies: 3
    Last Post: 06-15-2014, 04:35 PM
  3. FAIR Nexus 4 | 16GB | Case | Screen Protector
    By worldspy99 in forum Marketplace Archive
    Last Post: 06-13-2014, 12:41 AM
  4. Nexus 7 Hard Reset Won't Work
    By battenball in forum Google Nexus 7 Tablet (2012)
    Last Post: 05-30-2014, 03:22 PM
