12-25-2014 05:45 PM
51 123
tools
  1. datum9's Avatar
    Anything close to 3,000 mAh is completely insufficient to power up a smart phone for any serious length of time. I had a Optimus G pro with the stock 3400 mAh and only got something like 6 hours before it dipped below 25% and 25% of 3400 is very ltitle. It basically means "run to the charger" before it shuts down at the worst possible time. It lived on the charger so much I wore out the USB port in the phone. Because I liked to have at least 50% at all times, which doesn't last long at all.
    Got a ZeroLemon 9300 mAh cell, nice. It lost a little capacity over months, as any Li-Ion battery should, but I still get a solid day and night per charge. This is the battery smart phones need to come with. Maybe even more, between 10,000 mAh and 15,000 mAh. Because smart phones are basically mini-laptops now. They need to make the battery the size of the phone. Another benefit of ZeroLemon is that the phone is easier to hold now, being much thicker. There is nothing cool about smart phones the thickeness of a credit-card. Capacity is extremely low, they are slippery and hard to hold. Not a great idea from any angle.
    Now G3 is coming out, with the increased pixel count and increased power consumption for sure, yet they only put 3,000 mAh cell in it. How inappropriate. How long will the runtime be before you are in the danger zone, 4 hours?
    I think the low capacity and the 2mm thickeness is driven by the marketing departments. The engineering department will deliver a phone that can run for a week and be comfortable to hold but the marketing department will over-ride them and say, redesign it so it's paper-thin and runs for 4 hours so we can run commercials about how compact it is. The consumer is apparently dumb enough to buy it.
    Yet there is nothing good about compactness. I want a 1990s sized device that does not need to be charged in the morning, lunch and dinner and overnight also.
    The smart phone makers need to come up with 2 options, let's say "H" for high-capacity and "A", for "Armored", something water proof and protected against damage, much like Otterbox. I don't want an aftermarket "patch", but a build-in design around longest runtime instead of having to buy a device and get patches for it so it's adequate.
    07-07-2014 11:29 AM
  2. wizzrah's Avatar
    Some people do not like having a thick device in their pocket. You can't deny that manufacturers have come a long way in terms of battery capacity. They have been able to increase the amount of juice, which keeping thickness at a minimum. The trend of big display phones also helps because you can fit more in than you would with smaller devices.
    07-07-2014 11:37 AM
  3. Almeuit's Avatar
    The thickness would bother people.
    Sent from my T-Mobile Note 3 using AC Forums.
    wizzrah likes this.
    07-07-2014 11:41 AM
  4. TgeekB's Avatar
    Yes! Sign me up for a giant brick smartphone.
    Until the technology is better, it's not going to happen.
    wizzrah likes this.
    07-07-2014 11:48 AM
  5. dpham00's Avatar
    The s5 is waterproof. You might be willing to accept a heavy and thick device for smartphone, but most people are not. For people like you, you can buy a heavy duty case like the otterbox armor, which is rated for a 10' drop on concrete. I bought one for the 4s and 5s for $5 each on sale.
    Also, there are extended battery options like you mentioned. But the vast majority of people don't get it now.
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
    07-07-2014 12:11 PM
  6. LeoRex's Avatar
    They aren't putting in the smaller batteries because they want to... they are putting in smaller batteries because the HAVE to.... People don't want heavy, brick-like phones, they want them thin and light, so much so that they'll readily accept the lack of battery life in exchange for a phone that doesn't need its own seat on an airplane.
    There are fewer industries out there with a more watchful eye on battery technology..... a 10,000mah battery with the same dimensions and weight as a current 2000mah battery is like their Holy Grail.
    07-07-2014 12:34 PM
  7. datum9's Avatar
    If it's consumer driven, well maybe so, I get it, but the current state of smart phones, phablets and tablets and for that matter laptops is pretty sad, in my opinion. The whole point of wireless devices is to be away from the charger. They need to offer at least an option for those who want to be away from a charger for more than 2 hours.
    Had the orginal Droid, same story. It came with a 1600 mAh cell. Ridiculous. Upgraded to a 2600 mAh cell and even that was not enough and I carried about 3 spares.
    Had a Samsung S3, same story. Running out of juice before COB. Mostly on standby without much usage. Zerolemon was a nice addition, even 7200 mah one.
    I carry spare batteries in addition to zerolemon. Car charger is nice but you can blow the fuse, run out of gas or whatever comes up due to Murphy's law. Like stuck in a storm or some natural disaster without power.
    07-07-2014 12:48 PM
  8. Almeuit's Avatar
    For your situation datum it sounds like you use your phone a lot so I can see where you're coming from... But manufacturers look at it from a majority standpoint... They don't want to make a ton of one product and most people not want it since they want the cash.. They will go with what sells.
    It sounds like you know you use it due to spares... For now you'll have to do with that and the zerolemon cases. Until they can make the batteries bigger but not make the phone a brick... I don't see it happening anytime soon.
    07-07-2014 12:57 PM
  9. zorak950's Avatar
    Personally, I'm with datum: I wouldn't mind my phone being a few millimeters thicker if it bought me a few more hours of screen-on time. I'm pretty much resigned to the idea that if I want that, I need a removable battery, though.
    07-07-2014 02:28 PM
  10. TgeekB's Avatar
    I'll take the sleeker device with removable battery.
    07-07-2014 02:37 PM
  11. Sizzers's Avatar
    That's fine if you want a Samsung or LG but not everyone does, myself included.
    Also, the downside of ultra thin phones is their handleability. If you use your phone naked, unless you grip it just right they can have a tendency to just flip right out of your hand. I like a phone which my hand can properly hold on to, and if that means extra mAh....Great!!
    Sent from my XT1032 using AC Forums mobile app
    07-07-2014 03:30 PM
  12. bembol's Avatar
    So should I also ask for 3TB storage? Ask yourself when does it end why not 20k mAh?
    TBH I'm happy getting AT LEAST 12 hours with my last few Super Phones including my S5. I bought the Samsung Extra Battery Kit only because I had a coupon but it hasn't been an issue where I had to use it.
    Super Phones are getting bigger I don't need them thicker as well.
    Pro S5
    07-07-2014 03:52 PM
  13. TgeekB's Avatar
    I have large hands and a phone has never flipped out of them.
    07-07-2014 04:02 PM
  14. Almeuit's Avatar
    On the other scale I'm a small person and I can 1 hand the Note 3.. And have never dropped it.
    07-07-2014 04:20 PM
  15. erinxia's Avatar
    It's true though, some devices are way too thin and I practically have to charge my phone everyday, but I think going for a brick like type would be even more inconvenience even if it did give a longer battery life. I guess if anything, you can always buy an extra battery or a portable charger.
    07-07-2014 07:24 PM
  16. DickRilloa's Avatar
    Glue your S5 to one of these and nobody's the wiser:
    10,000 mAh battery needs to be standard in smart phones-motorola_dynatac_8000x.jpg
    tonyr6 and mrsmumbles like this.
    07-08-2014 11:21 AM
  17. datum9's Avatar
    It was a hyperbole to make a point and highlight the current deficiency, not to be taken literally.
    07-08-2014 11:58 AM
  18. datum9's Avatar
    I could not hold Droid X, or Samsung S3, or LG Optimus G Pro as they came out of the box. Thin and slippery. These 8 or 9 or so milimeters are not enough. The edge is too thin to get a postive grip on it. I first upgraded to a protective plastic contraption which helped and eventually got oversized batteries which came with their own thicker covers which helped even more. ZeroLemon extended batteries double the thickness it seems.
    Oh well, the customer is always right and always gets what he wants, too bad the average customer has the intelligence of a door knob.
    07-08-2014 12:03 PM
  19. DickRilloa's Avatar
    Don't count on it for the next couple of decades. NY Magazine:
    The Most Annoying Problem in Computing Is Still Unsolved
    07-08-2014 12:42 PM
  20. Duncan1982's Avatar
    I don't get the whole argument in phones lasting days on a single charge.
    With 2k screens becoming the norm I do believe a 4000mah battery would suffice.
    This would get any heavy user through a whole day, then charge when asleep, wake up and your good to go again.
    Why is it an issue to some to charge while sleeping?
    07-08-2014 07:35 PM
  21. rrballer11's Avatar
    I agree. Battery technology needs to advance.
    07-08-2014 10:36 PM
  22. msndrstood's Avatar
    I understand what the OP means. I find that the Note 3 with stock battery is 1) too thin, I do feel like it's going to flip out of my hands. I have MS and need to feel the heft of the device. 2) i have the Zerolemon 10,000 and it does give a feeling of security knowing that i have a connection. (Like now, with the power out, I'm using my 6400, when that runs out, I'll pop in the Zerolemon.) i do use the Anker 6400 as my DD, mainly because it fits in my clutch and the Zerolemon does not.
    07-08-2014 10:44 PM
  23. George Jenkinson's Avatar
    I wonder whether it's possible to view power demand/management from a different perspective?
    Why not create a device that has a solar panel beneath the display (like some watches have), or on the reverse that can keep the battery topped up continually? I'd favour this over a bigger phone needed to hold a bigger battery...
    07-09-2014 05:59 AM
  24. George Jenkinson's Avatar
    Whilst I know what you mean, the argument is a little bit like saying car fuel tanks only need to be big enough to last the majority of people's average daily mileage. The car can be topped up on the way home - after all why carry the extra fuel around which decreases the efficiency of the car?
    There's a happy medium to strike and I think rather than bigger batteries manufacturers need to look at power management and demand along with a say, a built in solar panel to keep it charging throughout the day...
    07-09-2014 06:06 AM
  25. TOTtomdora's Avatar
    Watches have those because they need very little power. With a phone, if the entire back was a solar panel, it would take at least a day of not being used to charge it up.
    Actually, now that I think about it... A day beats not at all.
    07-09-2014 06:26 AM
51 123
  1. Replies: 1
    Last Post: 02-26-2015, 12:50 AM
  2. rooting from a to z.
    By johnriii in forum Verizon Samsung Galaxy S4
    Last Post: 07-26-2014, 09:18 AM
  3. pls help out...moving files from internal to msdcard
    By mavericket in forum HTC One M8
    Last Post: 07-21-2014, 01:11 PM
  4. Phone Charging Incorrectly
    Last Post: 07-07-2014, 04:10 PM
  5. Replies: 0
    Last Post: 07-07-2014, 10:39 AM
