1. marios1441's Avatar
    I have a Samsung Galaxy Ace 3 S7275R
    mobile phone with Android OS and it
    has the Accuweather weather and time
    Widget and i have set it to auto-update the weather every hour but
    does not update it.
    09-01-2014 10:06 AM
  2. Golfdriver97's Avatar
    If you click on the widget, it takes you to the app, correct? Does it update then?
    09-01-2014 10:10 AM
  3. marios1441's Avatar
    No. It does not update.
    09-01-2014 10:32 AM
  4. Golfdriver97's Avatar
    Probably some kind of error in the app working on your device. You can try to email the developer, or you can try a different weather application. I like 1Weather.
    https://play.google.com/store/apps/d...expressweather
    09-01-2014 10:38 AM
  1. Panasonic P31 Wifi Problem
    Last Post: 11-15-2014, 01:11 PM
  2. HTC one m7 speaker problem
    By bens1986 in forum Ask a Question
    Last Post: 09-01-2014, 05:23 PM
  3. problem with google play store
    Last Post: 09-01-2014, 09:46 AM
  4. lost my widget icon
    By Jane1955 in forum Ask a Question
    Last Post: 09-01-2014, 05:06 AM
  5. e mail problem
    Last Post: 09-01-2014, 05:03 AM
