Weird data issue with Galaxy Note 3 - Verizon
AV1611
All:
I leave my wifi turned on at all times. When I'm at home my phone auto-connects to my home wifi network. When I'm at work my phone auto-connects to the public wifi connection there. My problem is my phone has been using my 4G data allowance both at home and at work to download from the Google App store and to watch Netflix. Netflix alone has used 1.5 gigs in the past 7 days. I have my phone set to update my apps and download new apps with wifi only. My wifi signal strength both at home and work is very good. What is going on? Verizon is sending me texts telling me that I've exceeded my monthly 2 gig data allowance in just 7 days.
frustrated and paying for data that he shouldn't have to in Nebraska...................
jpr
1,700
48
Make sure you have auto network switch turned off.
Of course you can always turn off your mobile data too if you want to be certain it's not used.
I'd also make sure that you have your WiFi set to be always on when asleep.
jpr
1,700
48
Okay, I just turned off mobile data, but where do I find "auto network switch"??
Is under your WiFi settings. Also see what I added about sleep. That's under advanced WiFi settings when you hit the menu button.
jpr
1,700
48
I believe he's talking about the connections optimizer under the mobile networks tab in your settings.
I have a TMO model. I don't have connections optimizer under mobile networks. So if you guys don't have auto network switch or smart network switch under wifi settings then yeah, try that. :) I'm assuming you still have the wifi always on when sleeping option?
dreamur
Active member
Apr 21, 2013
25
You can also use Trigger to automate tasks lke switching off your mobile data when you connect to a wifi (home or public) or switch mobile data on when you disconnect. Download from google store. You can also program a lot of other tasks.
steve1084
