I keep seeing every where that LTE is eating the battery so bad on the phones. How is the phone going to work properly if you can't even use it too long? Are people over reacting or is this really a big issue???
I don't think there's a doubt in anyones mind that LTE is going to be a battery hog. Exactly how much, we're not exactly sure. The good news is that LTE, just like WiMax on Sprint 4G devices can be turned off, so if you're that concerned about it you won't be forced to use 4G if you're in an LTE coverage area.
I see you're on the Storm.... Downloading a web page on your device and taking two minutes for it to render should equal out to the power used of an android taking two seconds to download that same page.
I'm a long time BB user and can tell you the battery on my phone now lasts a good 3-4 hours longer then it did on my BB. 4G will definitely take its toll on the battery but overall you will have better battery life then what you have now.
Dear lord...I feel for you, I had a Storm and wanted to kill myself.
Right now LTE is a first generation technology so its bigger and more power hungry than it will be later. When 3g first came around it was a power hog to. The thing to do is to use the LTE radio when you need to and shut it off when you aren't going to be needing the extra speed. If you're plugged in and want to stream a video then have at it otherwise use it sparingly.
That's going to depend on how good your 3G coverage is. I know in my area Verizon has a very strong 3G footprint and I have no problem streaming videos, even HD, over 3G.
It all depends on what application(s) you have installed on your device. Also, if you have conflicts going on with any modifications on the device. I'm not rooted and I haven't done any modification to my phone. Leaving all settings as stock — and also at a location where I'm getting excellent 4G coverage. Maybe that is why I don't see any significant battery consumption using 4G on my device.That's surprising then, because almost every one I know, and a lot of people here on the forums, has had lackluster at best battery performance when connected to 4G on the Evo or Epic.
