I was interested to see this article on battery life tips. I don't know the source's credibility. But over the years, I thought most had concluded here that there was no big deal in leaving a phone on the charger overnight, that modern tech took care of such things, that it had little impact.
ChargedCafe - Mistakes We Are Making While Charging Our Android SmartPhones
This site says instead: "Mistake #1: Leaving Phone Charging Overnight
It might seem like common sense to leave the Android phone on charge overnight so that when you wake up it is ready to go at 100% power....During the night the phone will charge to 100%, but once it has reached capacity, the charger simply does not turn off. The charger is going to send small pulses of energy to the battery because it does not realize it is full. Each time it sends those little pulses, it slowly eats away at the battery. Doing this continuously will cause the battery to drain faster when you use it over time."
I'm not sure I care all that much as I have removable batteries, but I was interested in this salvo on this issue. Rebuttals?
