A little heat from an electronic device like smart phones is normal. It's an unavoidable side effect of charging, discharging, processing and illuminating. If you Stick your hand behind the ventilation grille of an HDTV or a cable box, or the bottom of your laptop. These things are like space heaters. This is because lithium-ion battery??.
Just because gadget heat is normal doesn't mean it's good. To a user, excessive warmth emanating from a device may be irritating or even alarming.
a lithium‑ion battery stored at 40 percent charge and 104 degrees Fahrenheita realistic temperature for common cellphone usewill lose 15 percent of its capacity over the course of a year. That number jumps to 35 percent if the battery is stored at full charge, as in the case of a laptop that's left plugged in all day. Prevent heat with some ways of not using while charging like download, gamings, Put your phone as it is remove all cases or covers which covers it. make it free from all those which makes a closed environment.
