Results 1 to 6 of 6
    ashv3524's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Nexus 10 Speaker problem
    Hi,
    Is anyone else seeing speaker problems with the Nexus 10? My unit's left speaker is working, but not the right speaker. Last night both seemed to be fine (or I didn't notice, anyway). Just got the device yesterday :-(
    thanks,
    ashv
  2. Thread Author  Thread Author    #2
    ashv3524's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Nexus 10 Speaker problem
    Google Play support walked me through a factory reset over the phone and verified that it wasn't an equalizer problem. They're providing a replacement. fyi in case someone else runs into this issue.
  3. #3
    Amylase453's Avatar
    Posts
    Global Posts
    233 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No problems here, was it in all apps?
    ashv3524's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ShanMan14 View Post
    Yes, it was happening in all apps that use sound. No issue when using the headset.
  5. #5
    AlienSYQ's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My nexus 10 is suffering the same problem. Only the left speaker is working. So How did you fix that problem? Directly contact Google for a new one or just change some settings. I'm really confusing. Google nexus 10 is not on sale in my country. If it's really a hardware malfunction, contacting Google for a new replacement will be boring enough......
  6. #6
    Christopher Senn1's Avatar
    Posts
    Global Posts
    50 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    just got my Nexus 10 from ebay...used but in great condition. Only right speaker works. Going to test headphones then factory reset. But seems likely harware issue. You think I can return it to google instead of ebay seller?
  1. Speaker problems
    By NYY2SMP in forum Verizon HTC Thunderbolt
    Last Post: 06-28-2011, 04:17 PM
  2. New Nexus S, wifi problems (2.3.1)
    By jram05 in forum T-Mobile Nexus S
    Last Post: 03-03-2011, 02:22 AM
  3. Speaker problem after flash
    By EvoOWNSu in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 01-11-2011, 07:37 PM
  4. Speaker problems
    By gunsmoker in forum T-Mobile Optimus T
    Last Post: 11-13-2010, 09:06 AM
  5. Droid Speaker Problem
    By The Fed in forum Motorola Droid
    Last Post: 07-17-2010, 10:52 PM
