He don't have it he is bluffing!How much do we think it will be?
My battery was dead last night (0%). Plugged it into my computer, for at least an hour, and it actually died while it was plugged in...
Then from around 10.30pm it was plugged in to a PowerPoint, 8 hours later, its at 51%....
Charged my battery from 14% to 94% in 4h30 yesterday. Do you all think it's normal or not? The tablet was off.
It isn't nearly as fast as my old Xoom was, but how fast do i need it to be when I can charge it overnight.
Guys,
Do you think the stock charger suitable for Asia usage? I am from Malaysia and I just ordered a Nexus 10. Now, as I read, I am kind of worried the stock charger / adapter will not suit for Asia.
Can someone please enlighten me?
The stock charger should be fine - it has a range of 100-240V so its ok.
That's correct. You'll probably need an adapter to fit the plugs in country you visit, but the power itself should be fine. The power adapter is a transformer that converts AC to DC (5V), so as long as the AC input of the adapter can handle the output of that country's standard power outlets (and at 100-240V I'm pretty sure it can), you will be OK.
I meant power point... Obviously...
It took 21 hours to charge to 100% today...
Still don't know what you mean. As I said in the last post to you, "power point" is MS-Windows presentation software, unless you can elaborate. There is nothing "obvious" about your posting except that if it is taking 21 hours to charge, you are not using the factory charger or something is horribly broken.
