nexus 10 battery
Keith j
15
I am at 33% battery life and only been using nexus 10 for a little under 2 hours is this normal it was at 100% when I started
VeeArSix
11
What exactly were you doing on the tablet? If you were watching a movie at full brightness I could maybe see that amount of battery drain. If you were just browsing the web then that's definitely not normal.
CynicX
704
50
Its not impossible to make that happen but its by no means normal. I can get around 8 hours of screen on time before it dies, I usually keep the screen on its lowest brightness though.
Tyler Lietz
289
Remember the button on middle bottom right is actually active tasks, not recent apps so close unwanted apps and use your tablet obsessively for a few days to break in the battery after a few days my battery life improved by 60% also make sure its updated to newest version of android to fix any known bugs
lumpynose
129
If that was true then I should be able to click that 2 stacked windows button that's to the right of the home button, note the apps, then in the Settings app find them under Running apps. But that's not the case, so I don't think what you're saying is correct; rather than active I'd say suspended or recently suspended, and those use very little, if any, power.
lumpynose
129
I take that back; under runnung apps there's a show cached processes, and that says it's running. I still believe that they're suspended like ctl-z on unix, meaning they're occupying ram memory but not running. If my memory is correct the underlying o/s for android is linux.
vishaljanani
18
Hi,
I typically get around 5 hours of screen time before my battery runs out. My brightness is set to around 20-30% and I watch a lot of online streaming videos during this period and push it to my HDTV. Is this what one normally gets or is there a problem with my battery?
Appreciate your response and help.
Sent from my Nexus 10 using Android Central Forums
Keith j
15
Well guys got my new nexus 10 and the first one was definitely a bad one battery life out of the box is great the screen does not have the light bleed around the edges and it looks great.
Lee Griffiths
17
I'm not sure how to rate my battery, I thought it was OK but to me doesn't seem to last that long, at times I'm sure that it can drop more than 10% just general web browsing, I'm now on 25% after 1day 6hours, screen brightness about 30%. What's the best way to monitor your battery drain? Think I may keep a close eye on it after the next full charge. I've attached some screen shots of my current battery usage.
Cheers guys.
Kookas
72
Watching a movie, even at full brightness, shouldn't be able to drain the battery in 3 hours unless Android 4.2/Nexus 10 has serious battery issues. To be honest, nothing should be able to drain it that fast.
via Tapatalk
CynicX
704
50
via Tapatalk
Yes even glbenchmark on its highest battery test level with 100% brightness takes 3 1/2 hours, and that is designed to kill the battery.
mhitch02
Keith,
How long did it take to get your replacement??? I've done all I could with this battery...It doesn't actually charge completely overnight and drains excessively just surfing..Got it for Christmas but just had knee surgery and I'd hate to be without it....
Thanks,
Marc
Miss Elayn
18
Hello, mine use about 10% battery each hour at the lowest brighness and only surfing the web. Do you all think it's normal or not? Also, yesterday I charged the battery from 14% to 94% in 4h30... I heard it is supposed to be charged completely in 3 or 4 hours only... Is my battery and charge time ok? Although it is only my 2nd charge and I heard it should get better with time...
dgr_1983
3
I got my nexus 10 from CeX 10 days ago. I notice the usb part that connects to the tablet feels loose & doesn't slot in like how a charger with a mobile feels secure, is this normal?
1st charged it from 15%-100% it took maybe 12 hours or more. The 2nd time charged it from 25%-100% it took 9 hours & change.
Installed the update. Two hours on battery & it's down to 73%. It went from 84% to 77% battery in 50 minutes.
Bluetooth, GPS etc are off the screen brightness is down to 0/slider is to the left side. Played angry birds for about 20 minutes, watched ice age for about 10 minutes & the rest is surfing the net.
RonD
133
I think that the USB connection is the most fragile and failure prone part on the tablet. Sounds like you may have gotten a defective tablet. I would get a replacement. Also, consider getting the pogo charging cable.
AmeliaRodriguez
