1. roadrat's Avatar
    Are they they same output Amps?
    04-08-2013 07:59 AM
  2. alan sh's Avatar
    Yes and no. Yes, it works, no I don't think it provides the same power.
    Alan
    04-08-2013 08:16 AM
  3. paintdrinkingpete's Avatar
    Alan
    I think they are actually...5Volts, 2Amps?
    Don't have either one in front of me to check....
    04-08-2013 11:19 AM
  4. xlDeMoNiClx's Avatar
    Haven't been able to find a concrete answer but I'm guessing it would work since it should be teh same input, just might not work as well as the charger that came with the Nexus 10.
    04-08-2013 11:39 AM
  5. kilen71's Avatar
    Just checked mine, same output. 2.0 amps.
    04-08-2013 05:19 PM
  6. srfox's Avatar
    I have found that my N7 charger works on the N10 but it is much slower.
    Devlyn16 likes this.
    04-10-2013 09:13 AM
  7. Atiya's Avatar
    still using my broken nexus 10 charger
    04-11-2013 10:01 AM
  8. morridoom's Avatar
    From what I understand, both tablets require an input voltage of 5V/2A, but I would contact the manufacturers for confirmation just to be safe.
    04-11-2013 06:28 PM
  9. Atiya's Avatar
    good luck dude
    give us news
    04-12-2013 10:35 PM
  1. Email widget not working properly on galaxy tab 10.1 in ICS
    By ssaslow in forum Android 4.0 Ice Cream Sandwich
    Last Post: 09-15-2012, 02:13 AM
  2. Does Skype work now on the Thunderbolt?
    By 808TBolt in forum Verizon HTC Thunderbolt
    Last Post: 05-09-2012, 07:49 PM
  3. Does this portbale charger work with the galaxy tab 10.1?
    By xxxguitaristxxx in forum Samsung Galaxy Tab 10-inch
    Last Post: 06-20-2011, 03:29 PM
  4. Will the Pre Charger work with the Evo?
    By krue92 in forum HTC EVO 4G
    Last Post: 06-04-2010, 08:40 AM
  5. Replies: 7
    Last Post: 01-08-2010, 01:45 PM
