1. gfaceless's Avatar
    I'm amazed by the note taking feature of Galaxy Note 10.1 and I want it badly.
    But in the mean time I am not a big fan of stylus.
    So if not considering the stylus part, does Nexus 10 have the same ability to effectively take note?
    Like, Is it convenient for Nexus 10 to take whatever on the screen into a note (like an ebook or a web page or a playing video) before I can doodle around it?
    I'm assuming that S-Note is sort of system-built-in, which makes third-party note apps (like evernote) unable to do the same thing (like called directly during web browsing)
    04-21-2013 07:28 AM
  2. CynicX's Avatar
    Keep in mind the Note not only has software it has hardware the Nexus 10 is lacking for that level of accurate note taking.
    Sent from my Nexus 10 using Tapatalk HD
    gfaceless likes this.
    04-21-2013 09:17 PM
  3. xlDeMoNiClx's Avatar
    The Note 10.1 was designed for that kind of note taking so no.
    This is from me, on my EVO 3D.
    04-22-2013 09:45 AM
  4. PlanetPluto7's Avatar
    I just got a Wacom stylus from Bestbuy. The bamboo stylus works ok on the N10 in the Evernote drawing app called "Sketch". In gets my handwriting as fast as I can write. What apps would you want to use?
    04-28-2013 02:51 PM
  5. still1's Avatar
    I found this fully featured note taking app. obviously the S-Pen feature wont work on N10
    https://play.google.com/store/apps/d...projectpapyrus
    04-29-2013 02:01 AM
  6. still1's Avatar
    I also found another option. If you have ezpdf reader you can do all draw function on pdf.
    create a new pdf and you can annotate, add sticky notes,insert text/image, paint brush,pen function,spray, selection text etc
    can easily be managed since it is pdf.
    04-29-2013 01:20 PM
  1. Replies: 91
    Last Post: 01-10-2011, 02:19 PM
  2. Nexus S is the same or worse than Nexus One...
    By patfactorx in forum Rumored Devices Lounge
    Last Post: 12-01-2010, 09:38 AM
  3. Nexus S is the same or worse than Nexus One...
    By patfactorx in forum T-Mobile Nexus S
  4. Replies: 18
    Last Post: 06-18-2010, 10:01 PM
  5. Keep getting the same emails
    By NVR2ND in forum Verizon Droid Incredible
    Last Post: 05-05-2010, 09:09 AM
