Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 83
Like Tree8Likes
  1. #51
    anon5664829's Avatar
    Banned
    Posts
    Global Posts
    3,732 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Nexus 10 battery drain.......in an instant
    Quote Originally Posted by paintdrinkingpete View Post
    Glad you got it fixed.
    Just FYI, a factory reset does NOT uninstall updates. It only deletes all personal settings, data, and apps, leaving you with a "out of the box" configuration. Any updates that have been applied are permanent. If you do a factory reset with 4.3, it will still be 4.3 when it finishes.
    (I was actually shocked when I had to help my step-father factory reset his iPad and all the updates were gone!).
    Thats because he did not update the apps on iTunes.
  2. #52
    laynlow200's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Huh I didn't realize that. I wonder what the s/w update was then?
  3. #53
    HawaiianLaker's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    OEM Unlock + Root
    most of these issues seem like software, 95% of the time its apps keeping things awake. if i were you guys i would download something to monitor what uses the battery and what wakes the tablet, something like betterbatterystats or gsam battery monitor or wakelock detector. as for the OP, from he screen shots it seems as if your tablet froze, and drained the battery will trying to do whatever made it freeze. if factory resets don't work i would try re-installing the OS completely. hope this helps.
  4. #54
    crxssi's Avatar
    Linux: The power beneath
    Posts
    Global Posts
    2,990 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Interesting. I seem to have had something similar to this happen to ME for the first time, tonight. I was playing a game and suddenly it just went "poof" and the tablet said it was shutting down, with no notice. It would not turn on.
    So I plugged it in and it showed the battery icon, and I booted it up. Said 0% battery and charging. I *KNOW* it wasn't anywhere near 0%. So I checked the stats. Sure enough, the graph showed it was at 40% when it suddenly just went to 0% instantly and then shut down.
    So I left it on the charger and went and did other stuff for an hour. Came back and pressed the power button to see how far it had charged. Guess what.... the tablet was OFF again! Have no idea why. I had left it on. So I booted it up again and it is now showing a 19% charge. Very odd.
  5. #55
    tsells's Avatar
    Posts
    Global Posts
    4,093 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by crxssi View Post
    Any update on what's going on?
    I just had a similar issue. I was on an airplane watching a movie and the battery went from 65% to 0 in an instant and then shut off. I then charged up the N10 in my hotel and it did the same thing on my return flight. It went from 70% to 0 in an instant and then powered off. I went home and charged it up and it's working fine today.
    I'm concerned that I also might have a battery.
  6. #56
    crxssi's Avatar
    Posts
    Global Posts
    2,990 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by tsells View Post
    It has not done it since, so I have no further info.
    tsells likes this.
  7. #57
    tsells's Avatar
    Posts
    Global Posts
    4,093 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine is continuing to do it. I charged it last night and unplugged it this morning (it was at 100%). It was on my desk all day and when it got to about 70% it then just shut down with 0% battery. I plugged it in and restarted the phone. The battery is at 0 and it says it is charging.
    I'd appreciate any input from someone who could shed some light on this issue.
  8. #58
    tsells's Avatar
    Posts
    Global Posts
    4,093 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Today when the battery got down to 70%, the tablet immediately shut down as the battery went from 70% to 0% in an instant. This is the fourth time that this has happened and it appears as if the battery is defective.
    I spoke with Google customer service and they are replacing the device.
  9. #59
    crxssi's Avatar
    Posts
    Global Posts
    2,990 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah, being that consistent, it does sound like the battery went bad.
  10. #60
    tsells's Avatar
    Posts
    Global Posts
    4,093 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just got my replacement N10. Google made the replacement process really easy, especially since the device is a little over a year old! It is unbelievable how much "whiter" the screen looks on this new device. I always thought that my old device had a great screen, but the whites were much "yellower" on the old device as compared to the new one.
  11. #61
    Devlyn16's Avatar
    Posts
    Global Posts
    1,849 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Glad to hear from someone who has had a positve experiacne with the replacement process
  12. #62
    Umass021's Avatar
    Posts
    Global Posts
    1,596 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    I have only owned this for a day now and mine did the same thing. Charged it full then used it for the last day and a half and at 38% it went to 0 and shut off. I got this as a gift and am very upset that happened. I hope sending it in fixes the problem. I am going to attempt to call the number and see what they can do for me. Has anyone had this happen to them and go away? Very disappointing. I don't want to send it out for repair if it happens again.
  13. #63
    tsells's Avatar
    Posts
    Global Posts
    4,093 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Umass021 View Post
    I would try charging it up again and then seeing if the same thing happened. Mine would gradually drain to exactly 70% and then shut down, as the battery would be immediately at 0.
    See my post above. I spoke to Google customer service via email. He suggested doing a few things that I had already tried. When I told the customer service rep that I had already tried everything that he suggested, he asked if I wanted to return mine for a replacement. They took a credit card as a deposit (although just authorized but not charged), and sent me a new device and return info. I set up the new device and just returned the old one using a return sticker via pre-paid UPS.
  14. #64
    Umass021's Avatar
    Posts
    Global Posts
    1,596 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Did you have or need a proof or purchase? I got it as a gift and wasn't sure if it was needed. Also you said call google instead of Samsung correct?
    Sent from my XT1080 using AC Forums mobile app
  15. #65
    tsells's Avatar
    Posts
    Global Posts
    4,093 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I bought it through Google and they had a record of my purchase through my email address.
    Here is the contact info that I used:
    googleplay-support@google.com
  16. #66
    Umass021's Avatar
    Posts
    Global Posts
    1,596 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    I emailed them and will see what happens. I am currently charging my tablet now to see if happens again. I hope not buying it thru them doesn't hurt my chances of getting it done.
  17. #67
    Umass021's Avatar
    Posts
    Global Posts
    1,596 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    I charged my tablet to 100% again for the second time since I owned it and now running sling player to see if it drains correctly and maybe my battery needed to be broken in or maybe when I charged it the first time it wasn't really at 100%. We will see what happens.
  18. #68
    tsells's Avatar
    Posts
    Global Posts
    4,093 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hopefully it works fine now, but there is no "breaking in" period for these batteries.
  19. #69
    Umass021's Avatar
    Posts
    Global Posts
    1,596 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Yeah I figured but thought I would try it. Someone else mentioned in another forum saying it did the same thing and when they charged it the second time and it took forever but it didn't drain instantly again. I emailed Google with the address you gave me and see what they say.
  20. #70
    Umass021's Avatar
    Posts
    Global Posts
    1,596 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    My only hope is that it wasn't really 100% when I charged it the first time and the battery was reading wrong.
  21. #71
    crxssi's Avatar
    Posts
    Global Posts
    2,990 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes there is. There is with all Lithium Ion. They do not reach their full potential until several charging cycles have been completed. The N10 is no exception and I saw a marked improvement in battery life after a break-in period.
    tsells likes this.
  22. #72
    Umass021's Avatar
    Posts
    Global Posts
    1,596 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    I hope your right. I did fully charge it a second time and the battery drained correctly and didn't go to 0 instantly again. I let it go to 14% and then charged it full again. We will see.
    Sent from my Nexus 10 using AC Forums mobile app
    tsells likes this.
  23. #73
    crxssi's Avatar
    Posts
    Global Posts
    2,990 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am not saying that charging cycles will help with THAT problem. I was only correcting the posting saying that the N10 does not benefit from initial charging cycling, which it does. I estimate my battery life was extended by up to 25% higher.
  24. #74
    Umass021's Avatar
    Posts
    Global Posts
    1,596 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    I know I am just hoping for any good news that the problem doesn't come back.
  25. #75
    crxssi's Avatar
    Posts
    Global Posts
    2,990 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, time marches on. It has been 7 months since that posting and the problem now occurs regularly. I can play games for about 2 to three hours (maybe 2 or 3 sessions of an hour each without charging) and it will show about 80% or 75% battery left, but then suddenly pop up a warning of low battery and shut down! Bought mine in November of 2012 and use it most every day. I think the battery is just wearing out... it is just such a strange way to wear. Normally lithium batteries don't act this way in computers, you just see the life shorten over time linearly with the battery indicator acting properly, going from 100% down to 0%.
    Anyway, I think it might be time to consider replacing the battery. There are not a lot of choices out there. I can see the NewPower99 battery on Amazon ( Google Nexus 10 Battery Replacement Kit - Extended Life ) , which is a reasonable price at $60 + $6. But there are only 3 reviews. One review is invalid. One review is by someone who has only made one review ever, so I don't know if it is a real review. So there is really only one review, and it is positive. Has anyone else performed this battery replacement yet? If so, which battery did you use and are you happy with it?
  1. Battery draining at an alarming rate....
    By Canephins in forum Verizon Galaxy S3
    Last Post: 09-14-2012, 10:11 AM
  2. Stitcher has HORRIBLE battery drain in Froyo
    By DevilInPgh in forum Android Apps
    Last Post: 10-01-2010, 04:22 PM
  3. Replies: 6
    Last Post: 09-01-2010, 05:39 PM
  4. DoggCatcher battery drain in EVO
    Last Post: 08-31-2010, 05:01 PM
  5. problem: battery drain in 3hours
    By clayatx in forum Verizon Droid Incredible
    Last Post: 05-21-2010, 09:31 PM
