1. Mhanger's Avatar
    Battery has been fully charged several times, but when disconnected from the charger I have seconds before the unit goes dead. Will not start up until reconnected to the charger.
    I'm thinking that I will have to do a factory reset, but hoping someone has had this problem before and knows the root cause and the solution.
    Any help would be appreciated.
    Thanks in advance.
    Sent from my SGH-T999 using AC Forums mobile app
    06-24-2013 04:52 PM
  2. Mhanger's Avatar
    Sent it back to Samsung. They replaced the battery and now all is well!
    08-22-2013 09:32 PM
  1. Battery IssuePLEASE HELP!!!!!
    By Floridadomer in forum General Help and How To
    Last Post: 04-08-2011, 11:47 AM
  2. Battery indicator help
    By bor999 in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 03-11-2011, 11:59 AM
  3. Battery Icon Help
    By jt1028 in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 03-10-2011, 05:32 PM
  4. Battery Drain Help
    By Nytom30 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 12-30-2010, 11:21 PM
  5. Battery Life Help!!
    By KMfiremedic111 in forum Samsung Transform
    Last Post: 12-08-2010, 03:48 AM
