Results 1 to 11 of 11
    Default OTG Cable and Hard Drive or USB Stick
    Does anyone have a recommendation for an OTG Cable for the Nexus 10?
    Is the Nexus 10 cable or powering a 250gb SSD Drive in an enclosure or just a USB Stick?
    I saw recently this OTB/USB Hub that came out that supported 4 devices,,,
  2. #2
    Default Re: OTG Cable and Hard Drive or USB Stick
  3. #3
    srfox's Avatar
    Posts
    Global Posts
    179 Global Posts
    Carrier
    4.3 unlocked and rooted
    I bought two different ones of Amazon and they were both under $5.00. Both work just fine for memory cards. I have not tried a HD.
    Quote Originally Posted by xlDeMoNiClx View Post
    I say a similar one and someone said the design blocks the headphone jack. Any comments?
  5. #5
    I bought this one, though it is out of stock now. Straight plug so no potential interference with USB port.
    Newegg.com - USB OTG Black Host Adapter Cable for Samsung Galaxy S1 S2 S3 Note 2
  6. #6
    JasW's Avatar
    Posts
    Global Posts
    6,244 Global Posts
    I don't think the Nexus 10 can power a hard drive.
    Why would it have to if it's an external HD with its own power supply?
  7. #7
    Quote Originally Posted by JasW View Post
    He could be talking about one of the smaller ones that doesn't have it's own power supply.
  8. #8
    Quote Originally Posted by ffactoryxx View Post
    Sadly it does kind of cover over the headphone jack. If you have a small enough connector on your headphones then you can use both.
  9. #9
    JasW's Avatar
    Posts
    Global Posts
    6,244 Global Posts
    I'm not sure I've ever seen those in an external, but then again, I've never looked for one. In any event, I've hooked up an old (powered) external HD to the N10 with the OTG cable, and it works fine. Although I prefer to use the Plex app and just stream from my PC.
  10. #10
    I only need one external hard drive and it's one of the big ones that is powered by a wall outlet so I haven't been able to try it.
  11. #11
    I did get an OTG cable that has a 90-degree bend downward, thus blocking access to the headphone jack. I then got another one that was straight out, no access problem. I've heard there's one that has an upward bend. As far as powering a HDD, I've got a 500 GB Passport, about the physical size of the Galaxy Note 2 phone. This hard drive relies on USB power (it does not have its own power cable), and the Nexus 10 does not provide enough power for it. Any HDD that you connect to the Nexus 10 will need its own power supply. For portable, external storage, I use a bunch of 64 GB flash drives with the Nexus 10.
  1. New android user, htc one and storage
    By martin larsen in forum Introductions
    Last Post: 08-26-2013, 07:18 AM
  2. Replies: 3
    Last Post: 08-19-2013, 08:45 PM
  3. Replies: 2
    Last Post: 08-02-2013, 05:52 AM
  4. Could this be dust or a dead pixel?
    By coldjeanz in forum HTC One M7
    Last Post: 08-01-2013, 12:40 PM
  5. application for both viber and what's up messages?
    By lotrinidad in forum General Help and How To
    Last Post: 08-01-2013, 03:06 AM
