Results 1 to 15 of 15
    Default [HELP] problem after ROOT my nexus
    hello all,
    i really need your help.
    last week I've got my nexus 10 and was trying to ROOT it.
    I had some problems with it that i was solved by reading some guides and helpers....
    Now I have problem, I think with my SD card (internal storage).
    When I try to run Google play I get the message "Unfortunately, Google Play store has stopped.".
    When I try to download something from Google chrome I get the message "no SD card."
    When I try to run the cam app I get the message "No storage. No external storage available."
    I can't see anything when I connect it to my pc, and can't transfer nothing to/from the tab.
    Pls help me..
    Thanks a lot...
  2. #2
    Default Re: [HELP] problem after ROOT my nexus
    I would say the simplest was is to do a factory reset and don't root it again. Why exactly do you need to root it? Is there something specifically that you need to do that requires rooting?
  3. #3
    do a factory reset!
    I did factory reset for many time.
    Nothing change.
    I did root for some otg options. I dont know if its really need.
    I did it for many times...
  6. #6
    Did you move all of your sd to a 0.folder? Android 4.2.2 and up have the users so you have to move everything to a 0. Folder and your sd will be restored see if you can side load es file explorer
    Sent from my HTC One X+ using AC Forums mobile app
    How can i move it?..
    Maybe if i will install an old android version it will fix?
  8. #8
    You can find stock images here. I would install 4.2 and let it update later.
    https://developers.google.com/android/nexus/images
    there is only 4.2.2 and 4.3 there...
    do you know when can i find 4.2?
  10. #10
    Quote Originally Posted by Ohad Morgan View Post
    Ok if your rooted use es file explorer copy the games and paste them to your sd card
  11. Thread Author  Thread Author    #11
    i cant access to ny storeg.. i am really in trabels.
  12. Thread Author  Thread Author    #12
    Quote Originally Posted by patruns View Post
    its doesnt help... f***!!!
  13. #13
    Ok what exactly did you do? You un locked the boot loader put a custom recovery on it and flashed a su.zip?
  14. Thread Author  Thread Author    #14
    its complicated...
    i try to root and stuck in X nexus logo.
    then i try factory reset -> dosent help.
    then i have a battery issue -> i read a google guide about battery and succeed to fix it.
    then i have my storge prob!..
    now if i install a ROOT android i have SU, and if unROOT dont.
    what should i do?...
  15. #15
    its complicated...
    Step by step what did you do details are everything
  1. Rooted my phone. Just wanna go over what I did.....
    By HuntedDuck in forum Sprint Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 04-10-2014, 09:51 AM
  2. Rooting Samsung Galaxy Tab 2 10.1
    By Hawkeye6352 in forum Samsung Galaxy Tab 2 10.1
    Last Post: 08-11-2013, 04:02 AM
  3. New to Android - Some Help Please?
    By ManvirS in forum Samsung Galaxy S4
    Last Post: 08-10-2013, 07:45 PM
  4. Replies: 12
    Last Post: 08-09-2013, 07:20 PM
  5. HTC Desire X bugs after JB 4.1 update and slower after factory reset.
    By screw4445 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 08-09-2013, 11:56 AM
