Finally got my replacement battery
I have installed it with no issues thus far
The provided cd did not play on Vista, but did work on Windows 8, could not get to video on youtube any more
The screwdriver with the kit was no good (blunted end), but I had one that worked
It was a little tricky to get the case off- slow, easy and a little force when needed was the trick. I started on the long sides and learned you need to pry on the outside of the speakers. Once a corner came off the rest came off much easier, more of a slip it off rather than the original pry it off when the corner came off. A lot of snap crackle and pop of the case snap holders when removing the case.
The flip clips for the ribbon cables are very, very small, but flip easy when done correctly, Take note that 2 flip open in one direction the 3rd goes the other direction and the clips were black on mine - not the white part.
Putting it back together very easy
Battery was already charged
So far so good, now need to let it do it's thing for a bit to see power usage
