Jerry Runnels
I did find the you tube videos on how to replace the battery and i replaced it today. Unfortunately, when i powered it up the touch screen was unresponsive so i cant access anything on the tablet. The battery install went well so i cant understand why the touchscreen wont work. I cant get into any part of my Nexus 10 to to a hard reset and the external hard reset procedure doesnt work either. I cant get the tablet to go into Recovery Mode. All i can figure is that i did something to the ribbon cable which operates the touchscreen although i cant think of what it could be. I guess i will have to take the tablet apart again and disconnect/reconnect the ribbon cables to see if that works. Maybe i can start the tablet with the case still off to see if i have solved the problem before i put it back together. Otherwise im stumped. I think my tablet is in locked position when it boots up so i cant get anything on the screen to move etc until i can unlock the screen somehow.
