Okay, so I got everything ready. I spoke with Google, and spoke with t-mobile.
I called google, and if you live in the Missouri area, the s&h should be around $13-$14.
If you need a micro sim, don't worry about buying a cutter that you're going to use probably once, just call the number 1-877-453-1304, go through the choices till you get to the rep, and ask about a new micro sim. There's a special going on for a micro sim for only $0.99 and free shipping. Comes out to $1.07. You can activate it with a monthly t-mobile 4G plan for only $30 + some change.
The plan includes the following:
100 minutes of talk (I'm not a big talker, so I don't care)
Unlimited texting
Unlimited data(5GB's of '4G' then throttled to 3G)
Overall, this Phone, sim card, and $30 A month '4G' plan will cost around $350. If you have that...You're set.
Also, The Google rep told me that I should open play.google.com around 11:55, then spam F5 around 11:59 and have all your information ready to copy/pasta.
Just a few tips to help you get one of the first Nexus 4's. :-*
Unlimited texting
