Slender Troll
Something else I found. https://www.youtube.com/watch?v=GXOY9EVZ4vA
On the Telus network.
Motorola Photon 4G
Motorola Photon 4G
Tried it on my phone, no data connection at all. AT&T in a full LTE area.
Is there anything this phone can't do?
Hi- Android NOOB here on Rogers. I tried this but doesn't seem to work. Got into phone seetings and chose LTE Only. Is this correct? if so, nothing seems to happen, and I have no internet connection at all. Am i missing a step or did I do something wrong? Thx.
Ok, I tried again and chose the setting you chose. It showed 4G for a while and then reverted to 3G or H. I'm in a steel office tower in dowtown Toronto so i'm hoping its just bad reception in here (its always sketchy in my office) but it looks like it worked, if only for a short while. Will test it outside at lunch and see if it jumps to 4G.
I get the same problem, but I choose the one above the LTE only (LTE/CDMA/WHAT EVER WHAT EVER) and it did not work. However, I do not have an LTE plan, so that could be a problem.
Choose "LTE/GSM Auto". You need an LTE enabled micro-SIM card too.
Yes I tried mine outside and I got a very brief 4G, and then it hops around between 3G and H and grey bars. Also, tried to add the APN ddress but I go to my APN screen and there's nothing there at all. Strange. So I go through all the steps to add the new lte APN (for Rogers, as described) and it allows me to save, but still nothing shows up on the APN page. Not sure what's going on.
You're a genius! Restarting worked. Alllowed me to add the new APN (in addition to the Rogers and Chatr APNs that showed up), and now I have a steady 4G signal and a very speedy connection. . Thanks a ton!
No voice though right?
