Just wondering how its working with the Nexus 4 so far, does the LED indicator work with apps such as whats app on the nexus 4? Is light flow set up to work with the new 4.2 operating system? Is it worth paying for?
Thanks!
Printable View
Thanks!
I got the lite version which works for everything I need. Never tried on personal apps, I can't see that option. So far very pleased with this and I doubt I will get the paid version at all.
I'm only considering getting the paid version because the LED sucks for the 1st party apps, and the lite version doesn't support whats app which I use a lot. But just wanting to make sure its fully functional with the N4.
Using light flow, it conflicts with gosms a lot though
How is battery life affected with using light flow?
