Page 10 of 15 FirstFirst ... 78910111213 ... LastLast
Results 226 to 250 of 374
Like Tree61Likes
  1. #226
    cormaster628's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: -------Nexus 4 Battery Life (Horrible, Major drainage!)-------
    Honestly I'm betting 4.2 is the problem. I mean the Optimus G gets better battery life and benchmarks with a skinned ics 4.03, that tells you something right there! When a skinned oem version of android outperforms pure android you know you have a problem!
    Sent from my HTC PH39100 using Tapatalk 2
  2. #227
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Quote Originally Posted by monkey28rb View Post
    I took off the Weather Channel widget.. I'll see if that helps
    You may want to look at how your phone is syncing. I set some apps to sync every 2 hours rather than all the time. But this shouldn't matter as much when it's asleep. I would also just turn off data, WiFi, Bluetooth and GPS while you are sleeping. This makes a difference.
    Sent from my SGH-T989D using Android Central Forums
  3. #228
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Quote Originally Posted by cormaster628 View Post
    I agree. May be worth seeing if you can flash an older version of JB until they sort it out.
  4. #229
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't know how possible that is on the 4,but with 5 weeks to go till its in my hands hopefully they get it sorted out.
    badbrad17 likes this.
  5. #230
    monkey28rb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by badbrad17 View Post
    Yea I understand that would make a difference lol. But why should I need to do that every night before I go to bed. I believe the power management system on this is flawed. Hopefully an update will come out to fix this.
  6. #231
    DEVILDOG78965's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.2.1
    Quote Originally Posted by stiawdftw View Post
    I guess I should contribute to the thread. 5 hours since charge with moderate texting (20 or so sent/received) and some internet browsing and other random things. Auto brightness turned off and location services turned off. I also use app killer and its set to every 30 minutes. Connected to Telus LTE network as well. I still have 73% remaining. I had the expandable 2000mah battery from samsung for my gnex and the N4 battery lasts longer for sure. The original battery in the gnex was horrible compared to the N4. I think people are just overusing the phone because its new.
    That's what I'm thinking about people about using there phone because I am and I already used about 3 gb of data on my phone luck I got 16 gb.
  7. #232
    Citizen Coyote's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Marshmallow!
    Quote Originally Posted by ikerJ View Post
    Hi! I've been reading the whole thread after I've discovered my phone's battery is draining way too fast. And I mean... fast. I'll upload a capture later, but 15% can go away easily in 10 minutes.
    That started happening yesterday. Until then, everything was working fine. More than perfect, I'd say. Even with the latest update (lucky me!). I could go 24 hours without charging it, sometimes even more. The thing is that yesterday evening, at an electronics shop, I was considering buying an alarm clock with a USB connector so my phone can sit there overnight to be charged. I tried my phone with a couple of them when suddenly, after trying to play music on one of devices, the cell phone goes off. Which was weird, because half of my battery was full. It took me a while to turn it on. And since then, bam, draining like crazy. 50 minutes means 25% battery less, without using it. And that's after a factory reset. I read about the Exchange bugs but since I am not using that service it does not apply to me.
    Have any of you guys had similar issues?
    Not with a Nexus, no, but that sounds very similar to what happened to my original iPod Touch. I had an older HDD-based iPod and received a clock radio/dock as a present. Then the old iPod was stolen, and I replaced it with the first gen Touch. Battery life was fine at first, but a day or two after using the dock with the new player, my battery life was horrible. Apple Store confirmed something was seriously wrong with the battery and replaced it, but I'm convinced the dock somehow fried it.
    It's possible something similar happened to you, that drain is definitely not normal. You can either contact Google for a replacement, or you can try reflashing the stock Android 4.2.1 image and see if that resets something (see the first post in the rooting/rom subforum for info).
  8. #233
    dave9851's Avatar
    Posts
    Global Posts
    199 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery going down fast. 49min screen time, 60%
    Any ideas? As of now, this is the worst battery life I've had on any android phone I've owned. Have auto brightness off and level set pretty low too.
  9. #234
    John-Smith's Avatar
    Posts
    Global Posts
    462 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM 9.1
    Default Re: Battery going down fast. 49min screen time, 60%
    It could be the
    severinj likes this.
  10. #235
    cnguyen0320's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by John-Smith View Post
    It could be the
    Yeah? I hear that's awful
  11. #236
    cynicist's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Post some screenshots of your battery stats. It's likely an app, at least that is where I would start. You could try installing GSam Battery Monitor to help you find out where the drain is coming from. Also what is the total usage time on your phone? 49 minutes of screen time with 60% battery left is not bad at all if the phone has been on for two days for example.
  12. #237
    yfan's Avatar
    Posts
    Global Posts
    912 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dave9851 View Post
    What were you doing in this screen time? Not all screen time is created equal. For example, playing a high def streaming video on your phone for 49 minutes will consume more battery than 49 minutes of facebook updates. The more data/bandwidth intensive your task, the more battery it will use.
  13. #238
    nj1266's Avatar
    Posts
    Global Posts
    410 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default -------Nexus 4 Battery Life (Horrible, Major drainage!)-------
    Quote Originally Posted by ramnitb View Post
    To be fair android battery life really isn't all that terrible. My sister's iphone 5 drains just as fast lol
    Then your sister has a bad iPhone 5. Mine lasts about 22-24 hours between charges and has 8-9 hours of usage. My usage is mostly with the screen on, ie, texting, web browsing, navigation, emailing and reading the news on zite, clipboard etc. here is my latest sample
    Sent from my iPhone 7
  14. #239
    dave9851's Avatar
    Posts
    Global Posts
    199 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    All chrome browsing, but I've had the same usage on all android phones I've owned.
  15. #240
    severinj's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I got 2.3 hours of on screen time at about 40% brightness, but that was starting out of the box at 60% (no charge)
    that was with everything on, on low signal hspa+ inside my house. lots of texting and downloading apps as well as a bit of youtube in hd. i was impressed with that, because with a full charge I should assume I'll probably end up with about 4+ hours of screen on time. I don't even have the time to have my screen on for 4 hours in a day.
    Also I don't believe anyone telling me an iphone 5 lasts 8-9 hours with screen on. That is borderline ridiculous and imo completely unnecessary.
  16. #241
    nj1266's Avatar
    Posts
    Global Posts
    410 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by severinj View Post
    Believe what you want. I am telling you what I regularly get with my iPhone 5. I am not the only one either. On imore there are others getting what I am getting. Granted there are some that do not. But they are in the minority.
    I have my phone set-up as follows:
    Three emails that fetch data every hour.
    Screen set to auto
    Vibration is set to off
    Bluetooth is on for my car
    Wifi at home
    LTE everywhere else
    GPS is on all the time but not for all apps.
  17. #242
    severinj's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by nj1266 View Post
    Screen set to auto
    Wifi at home
    LTE everywhere else
    Are you telling me this phone would easily last you 2 days of 4 hours of screen on time per day? The iPhone 5 is fully capable of lasting you Saturday morning until Sunday night if you only use the screen 4 hours a day?
  18. #243
    severinj's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Also I forgot to take into account it has a smaller display to light up, so maybe the nexus 4 would be closer to 5 hours with a 4".
  19. #244
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Honestly battery management is nothing new. You can choose to not do it as long as you are okay with a dead battery. You have to adapt.
  20. #245
    nj1266's Avatar
    Posts
    Global Posts
    410 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I said one day=24 hours. The phone lasts me one day between charges during that one day it spends about 8-9 hours in use. I text, email, read the web about cars, read tapatalk, read about politics using Zite and Flipboard. Sometimes I check Facebook but not much lately. I use some of the 225 apps that I have on my phone. I use my gym goal app to log my workouts, for example. I rarely listen to music or the radio. Sometimes I use navigation. Bluetooth, wifi, GPS are always on.
  21. #246
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    And you are on this forum why?
  22. #247
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Something JB
    Screen set to auto
    Wifi at home
    LTE everywhere else
    Your still not getting nine hours of screen time. There is not one review/test/benchmark/user experience that I have seen or read yet that goes that high.
    Sent from my X-Band Modem... TY Genesis
  23. #248
    saadi703's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by iortiz55 View Post
    So I'm thinking about getting the iPhone 5 then. But I'm still skeptical, heard it's not that much better in terms of battery life. Cause having a long-lasting battery is the number one thing I look for in a smart phone. I would get the RAZR but I don't want Verizon and their prices haha
    Get a note 2 then which has screen on time from 6 to 9 hours under normal use. Under video play back 12-14 hours. If you don't want note 2 then buy any good phone with extended battery.
  24. #249
    saadi703's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    iPhone 5 lasting 8-9 hours is a lie. I used to have one and it never lasted long and with my usage which consists of gaming as well it never even reached half of the time mentioned here. From time to time I have owned every other iPhone and I was never impressed by battery life.
  25. Thread Author  Thread Author    #250
    iortiz55's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Jack Stephenson View Post
    Get a galaxy note 2, it has amazing battery life and u can get it on all 4 of the major U.S. carriers.
    Nah that phone is too big haha s3 was as big a phone I'll go. And I like having updates as soon as they're released not having to wait months. A major reason I returned my s3 for the nexus 4. But I did sell my nexus 4. I'm shipping it out on Monday. I expected a lot more from the battery, regardless of what anyone says.
  1. Droid Charge vs Nexus battery life?
    By Burchamj in forum Verizon Galaxy Nexus
    Last Post: 05-24-2012, 06:41 PM
  2. Coming from a Nexus.. Battery life question
    By jdtftp1 in forum Verizon HTC Rezound
    Last Post: 04-01-2012, 01:41 AM
  3. galaxy nexus battery life
    By austinmueller99 in forum Verizon Galaxy Nexus
    Last Post: 02-10-2012, 07:30 PM
  4. Nexus Battery life... Face Lock???
    By Clancy3434 in forum Google / Samsung Galaxy Nexus
    Last Post: 12-26-2011, 06:36 PM
  5. AT&T Galaxy Nexus - Battery Life?
    By scottder in forum Google / Samsung Galaxy Nexus
    Last Post: 12-19-2011, 10:07 PM
