Page 9 of 15 FirstFirst ... 6789101112 ... LastLast
Results 201 to 225 of 374
Like Tree61Likes
  1. #201
    ssgmun5000's Avatar
    Posts
    Global Posts
    52 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: -------Nexus 4 Battery Life (Horrible, Major drainage!)-------
    30% gone in 3 hours. I did have live wallpaper and just shut it off. Does draining to 0% and recharging really help?
  2. #202
    Xelion's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, I was a little worried, but so far, its better than my HTC inspire 4g by far. 14 hours on battery (5 hours while sleeping) and currently sitting at 55%. 20 minutes of GPS was used and 1.5 hours of display. I could see if I'm on it all the time it would be a problem but for the most part I use my phone for light internet browsing, some reddit, and GPS.
    Also, GPS is amazing. I often can lock on in under a second while in doors. My old phone would take minutes outside in clear sky.
  3. #203
    ssgmun5000's Avatar
    Posts
    Global Posts
    52 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    At 53% after 6.45 hours. Seems to be comparable to my gnex so far.
  4. #204
    Citizen Coyote's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Marshmallow!
    How many of you seeing abnormal battery drain updated to 4.2.1? Anyone not update with bad battery? Has anyone else tried what peejay did and reflash 4.2.1?
    For what it's worth, I'm on 4.2 with most options on default. I've been on wifi most of the day. After almost 8 hours on battery, I'm sitting at 79% left with light usage (mainly setting up apps and such). I'm sure that will drop tonight once I get home from work and start really customizing the phone finally. As a comparison, my Photon on 2.3.4 is showing nearly identical results, and I've purposefully used it about as much as the N4 today.
  5. #205
    peejay1977's Avatar
    Posts
    Global Posts
    199 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default -------Nexus 4 Battery Life (Horrible, Major drainage!)-------
    My map usage hasn't gone down by much since I turned the "Update location automatically from this device" off so I'm considering turning it back on and seeing what is going on.
    If it doesn't affect the battery life, working logically it leaves only a small number of possible causes :
    1. The 4.2 image out of the box, with OTA 4.2.1 on top sometimes causes issues.
    2. I installed an app which causes massive drain even though nothing shows in the list.
    3. Rooting it and unlocking the boot loader introduced an issue.
    4. Google account syncing is draining it.
    I now have Google Sync off during the day as I have no immediate need to have my contacts, calendar, messages and all the other stuff sync'd periodically. I might also turn this on and see what effect it is.
    Personally, I think the hardware is largely fine, I've known people with iPhones out the box have terrible life and others great life. I think it's likely to be more OS level thats not quite right, or a common app or setting people seem to use.
    It would be interesting to draw up a list of people with good and bad experience, a cross section of settings to see if a pattern emerges.
    Paul.
    Sent from my iPad using Tapatalk HD
  6. #206
    Jnorton2724's Avatar
    Posts
    Global Posts
    790 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Getting about 2h30m to 4h screen time on my Nexus depending on what I'm doing. 10 to 14 hours without a charge with my daily usage.
  7. #207
    ikerJ's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi! I've been reading the whole thread after I've discovered my phone's battery is draining way too fast. And I mean... fast. I'll upload a capture later, but 15% can go away easily in 10 minutes.
    That started happening yesterday. Until then, everything was working fine. More than perfect, I'd say. Even with the latest update (lucky me!). I could go 24 hours without charging it, sometimes even more. The thing is that yesterday evening, at an electronics shop, I was considering buying an alarm clock with a USB connector so my phone can sit there overnight to be charged. I tried my phone with a couple of them when suddenly, after trying to play music on one of devices, the cell phone goes off. Which was weird, because half of my battery was full. It took me a while to turn it on. And since then, bam, draining like crazy. 50 minutes means 25% battery less, without using it. And that's after a factory reset. I read about the Exchange bugs but since I am not using that service it does not apply to me.
    Have any of you guys had similar issues?
  8. #208
    Kakito24's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ikerJ View Post
    That started happening yesterday. Until then, everything was working fine. More than perfect, I'd say. Even with the latest update (lucky me!). I could go 24 hours without charging it, sometimes even more. The thing is that yesterday evening, at an electronics shop, I was considering buying an alarm clock with a USB connector so my phone can sit there overnight to be charged. I tried my phone with a couple of them when suddenly, after trying to play music on one of devices, the movie goes off. Which was weird, because half of my battery was full. It took me a while to turn it on. And since then, bam, draining like crazy. 50 minutes means 25% battery less, without using it. And that's after a factory reset. I read about the Exchange bugs but since I am not using that service it does not apply to me.
    I fixed my issues with one of best Custom Rom along with one of the best Kernel. Rasbeanjelly Rom by Rascarlo and Trinity Kernel by Morfic.
    Very good battery life and phone is nice, smooth and fast.
    Nexus 4 (RASBEANjelly: Trinity Four Inception)
    via Tapatalk 2
  9. #209
    foolishfocus's Avatar
    Posts
    Global Posts
    88 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm extremely happy with the battery life compared to my old HTC One X, it was almost dead by late afternoon
    Attached Thumbnails Attached Thumbnails -------Nexus 4 Battery Life (Horrible, Major drainage!)--------uploadfromtaptalk1354938893125.jpg   -------Nexus 4 Battery Life (Horrible, Major drainage!)--------uploadfromtaptalk1354938905739.jpg
  10. #210
    ikerJ's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Kakito24 View Post
    via Tapatalk 2
    Did you have your battery problems after an update? Or it was suddenly as it happened to me? I'm very laid back when it comes to deal with the guts of the phone, so before spending time in installing and rooting and dealing with these I'd like to have more information about your issues And thanks for the help!
  11. #211
    cormaster628's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sure you don't have an htc vivid? Click image for larger version.
    Sucks to hear the nexus 4 isn't much better
    Sent from my HTC PH39100 using Tapatalk 2
  12. #212
    Kakito24's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No problem. Initialy I felt like the battery life was not what I expected from this phone. I feel like from the beginning the battery was not that great. My friend also has an N4 and came out of Galaxy Nexus and he says his battery was ok. He was not complaining. We both moved on to Custom Rom mostly because he had already had used it on his Galaxy Nexus and told me this Rom and Kernel were the best for battery life and phone response. Hope this info helps.
    Overall I am Satisfied with the N4.
    via Tapatalk 2
  13. #213
    Go Ogle's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What do? Brightness is at 10% or none. Streamed two hours of Pandora and Play. Is two hours normal with full signal for 95% if the life?
    Attached Thumbnails Attached Thumbnails -------Nexus 4 Battery Life (Horrible, Major drainage!)--------uploadfromtaptalk1354944071770.jpg   -------Nexus 4 Battery Life (Horrible, Major drainage!)--------uploadfromtaptalk1354944117222.jpg
  14. #214
    Jack Stephenson's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What would you like more, 3.5 hours of screen time on an absolute beast of a phone with the most advanced mobile OS, or 4-5 hours of screen time on a weak phone with an archaic, dumbed down OS?
  15. #215
    ramnitb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock rom now
    To be fair android battery life really isn't all that terrible. My sister's iphone 5 drains just as fast lol
  16. #216
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by foolishfocus View Post
    Whats your secret?
  17. #217
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by iortiz55 View Post
    So I'm thinking about getting the iPhone 5 then. But I'm still skeptical, heard it's not that much better in terms of battery life. Cause having a long-lasting battery is the number one thing I look for in a smart phone. I would get the RAZR but I don't want Verizon and their prices haha
    Get a galaxy note 2, it has amazing battery life and u can get it on all 4 of the major U.S. carriers.
  18. #218
    xstinkyx's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Below is the result after my first full day of using the N4 (after having it charging all night the first time).
    I don't know if it's "normal" or not, but I just though I'd add another data point.
    If you see anything odd in it, let me know.
    Also, after it reaches 100% charge, is it better to unplug or or leave it plugged in? Say it reaches 100% at 1am and you aren't planning on waking up and fleeing with it until 8am.
    Attached Thumbnails Attached Thumbnails -------Nexus 4 Battery Life (Horrible, Major drainage!)--------screenshot_2012-12-07-21-08-06.png   -------Nexus 4 Battery Life (Horrible, Major drainage!)--------screenshot_2012-12-07-21-08-19.png   -------Nexus 4 Battery Life (Horrible, Major drainage!)--------screenshot_2012-12-07-21-08-13.png
  19. #219
    cynicist's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by xstinkyx View Post
    Looks great!
    Leaving it plugged in isn't a problem. Modern phones will actually hit 100% and then just trickle charge to maintain it, which is why you'll sometimes see your phone at 98% or 99% when taking it off the charger.
  20. #220
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey on this subject can someone explain to me proper charging techniques? I ordered a nexus 4 but won't have it till January, but in the meantime I'd like to know the proper way to charge it as with a built in battery, replacement isn't an option
  21. #221
    monkey28rb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Battery sucks on this thing. Phone drained 40% over night. Went to bed with 57% woke up with 14%..... I am not sure how you guys use these things, but it drains much faster than my iPhone 5.
  22. #222
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    This is exactly what I'm hoping for. 4 hours of screen time.
    Btw that is some crazy Emoji action you have. I wonder if Go SMS is a battery hog?
    Sent from my SGH-T989D using Android Central Forums
  23. #223
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Quote Originally Posted by cormaster628 View Post
    Plug it in, charge it all the way. Don't let it drain down to 0% if you can help it. Try to charge it at around 10%. There isn't much more to know. Lithium Ion batteries are smart.
  24. #224
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Quote Originally Posted by monkey28rb View Post
    There appears to be a rouge app causing drain while it is sleeping. You may want to install GSM battery monitor to see if this is the case.
  25. #225
    monkey28rb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by badbrad17 View Post
    I took off the Weather Channel widget.. I'll see if that helps
  1. Droid Charge vs Nexus battery life?
    By Burchamj in forum Verizon Galaxy Nexus
    Last Post: 05-24-2012, 06:41 PM
  2. Coming from a Nexus.. Battery life question
    By jdtftp1 in forum Verizon HTC Rezound
    Last Post: 04-01-2012, 01:41 AM
  3. galaxy nexus battery life
    By austinmueller99 in forum Verizon Galaxy Nexus
    Last Post: 02-10-2012, 07:30 PM
  4. Nexus Battery life... Face Lock???
    By Clancy3434 in forum Google / Samsung Galaxy Nexus
    Last Post: 12-26-2011, 06:36 PM
  5. AT&T Galaxy Nexus - Battery Life?
    By scottder in forum Google / Samsung Galaxy Nexus
    Last Post: 12-19-2011, 10:07 PM
