monkey28rb
Battery sucks on this thing. Phone drained 40% over night. Went to bed with 57% woke up with 14%..... I am not sure how you guys use these things, but it drains much faster than my iPhone 5.
Below is the result after my first full day of using the N4 (after having it charging all night the first time).
I don't know if it's "normal" or not, but I just though I'd add another data point.
If you see anything odd in it, let me know.
Also, after it reaches 100% charge, is it better to unplug or or leave it plugged in? Say it reaches 100% at 1am and you aren't planning on waking up and fleeing with it until 8am.
Hey on this subject can someone explain to me proper charging techniques? I ordered a nexus 4 but won't have it till January, but in the meantime I'd like to know the proper way to charge it as with a built in battery, replacement isn't an option
Sent from my HTC PH39100 using Tapatalk 2
There appears to be a rouge app causing drain while it is sleeping. You may want to install GSM battery monitor to see if this is the case.
Sent from my SGH-T989D using Android Central Forums
I took off the Weather Channel widget.. I'll see if that helps
Honestly I'm betting 4.2 is the problem. I mean the Optimus G gets better battery life and benchmarks with a skinned ics 4.03, that tells you something right there! When a skinned oem version of android outperforms pure android you know you have a problem!
You may want to look at how your phone is syncing. I set some apps to sync every 2 hours rather than all the time. But this shouldn't matter as much when it's asleep. I would also just turn off data, WiFi, Bluetooth and GPS while you are sleeping. This makes a difference.
I guess I should contribute to the thread. 5 hours since charge with moderate texting (20 or so sent/received) and some internet browsing and other random things. Auto brightness turned off and location services turned off. I also use app killer and its set to every 30 minutes. Connected to Telus LTE network as well. I still have 73% remaining. I had the expandable 2000mah battery from samsung for my gnex and the N4 battery lasts longer for sure. The original battery in the gnex was horrible compared to the N4. I think people are just overusing the phone because its new.
Hi! I've been reading the whole thread after I've discovered my phone's battery is draining way too fast. And I mean... fast. I'll upload a capture later, but 15% can go away easily in 10 minutes.
That started happening yesterday. Until then, everything was working fine. More than perfect, I'd say. Even with the latest update (lucky me!). I could go 24 hours without charging it, sometimes even more. The thing is that yesterday evening, at an electronics shop, I was considering buying an alarm clock with a USB connector so my phone can sit there overnight to be charged. I tried my phone with a couple of them when suddenly, after trying to play music on one of devices, the cell phone goes off. Which was weird, because half of my battery was full. It took me a while to turn it on. And since then, bam, draining like crazy. 50 minutes means 25% battery less, without using it. And that's after a factory reset. I read about the Exchange bugs but since I am not using that service it does not apply to me.
Have any of you guys had similar issues?
It could be the
What were you doing in this screen time? Not all screen time is created equal. For example, playing a high def streaming video on your phone for 49 minutes will consume more battery than 49 minutes of facebook updates. The more data/bandwidth intensive your task, the more battery it will use.Any ideas? As of now, this is the worst battery life I've had on any android phone I've owned. Have auto brightness off and level set pretty low too.
To be fair android battery life really isn't all that terrible. My sister's iphone 5 drains just as fast lol
