Results 1 to 24 of 24
    Default Need NFC help.
    I've been trying to send pics and other stuff between my nexus 4 and my wife's gs3. When I try to send something from her gs3 to my n4 it takes me to the play store and says item not found. When I try to send something from my n4 to her gs3, nothing happens. Any thoughts? Thanks in advance.
  2. #2
    Default Re: Need NFC help.
    Quote Originally Posted by chrispher86 View Post
    Oops! I mis-read the question.
    Why? What did you think it said?
  4. #4
    Ya I can't send anything via Android beam to my girlfriends HTC One X either. The NFC works but nothing happens after touching the screen.
  5. #5
    yep tried to send a photo to a droid razr maxx hd, and it didnt work for either of us.
  6. #6
    Probably because its different hardware..? Anyone know for sure? Does Android beam only work with two of the same device(N4 to N4, etc)?
  7. #7
    In another forum, I read that NFC transfers actually take place over a Bluetooth connection. It seems this requires that both devices have Bluetooth turned on.
    Have you guys tried that?
  8. #8
    dmorand's Avatar
    Posts
    Global Posts
    13 Global Posts
    That would seem stupid because then it's using bluetooth not NFC right?
  9. #9
    From what I know and figured out on my own. The GS3 uses DLNA to transfer files between each other while the Nexus line uses bluetooth for files like pictures and videos. That is the reason you can't NFC between the two. The other thing you have to know is that the GS3 is still running an earlier JB version where you weren't able to NFC pic/videos. You have to wait for GS3 to get the 4.1+ JB update where they allow for NFC to transfer pic/videos. NFC will make a connection between the two phones through bluetooth even if your bluetooth is off. The reason is because it will turn it on temporarily to transfer the file then turn it back off if it was previously off. This is from what I know of please correct me if i'm wrong.
  10. #10
    What I read is that NFC is used only to establish the connection, but that the actual transfers take place over bluetooth.
    In fact, right here: Jelly Bean feature: Sending photos and videos over Android Beam | Android Central
    In Android 4.1 Jelly Bean, Android Beam -- that's the NFC-based device-to-device transfer service -- has been augmented to support sending photo and video content. This is done from within the Gallery app, and can be activated by holding two NFC (Near-Field Communication)-supporting Jelly Bean devices back-to-back while one has an image or video open. Then, when prompted, tap the screen to send, just like earlier Android Beam incarnations. File transfers themselves are handled by Bluetooth, so depending on your device's Bluetooth version support, your transfer speeds may vary.
    I think the sending phone is smart enough to turn on its own Bluetooth transceiver, but it is not clear if the receiving phone will do so. I did read that pairing is automatic so the devices do not need to have been previously paired.
  11. Thread Author  Thread Author    #11
    No haven't tried that yet
  12. Thread Author  Thread Author    #12
    Still doesn't work
  13. #13
    trter10-imore's Avatar
    ThunderboltTool Developer
    Posts
    ROM
    Liquid JB v2.1 Alpha6
    At least one person in my family is getting a RAZR M (with 4.1) So I can test one of the theories when it arrives.
    Quote Originally Posted by o0cdiddy View Post
    ...we should rename the TB the Menstrualbolt
    If you like something i have done and would like to contribute my nerd fund, you may do so here
  14. #14
    Samsung/HTC messed up android beam gs3 uses galaxy beam and idk what HTC uses
  15. #15
    YoSaintLaurent's Avatar
    Posts
    ROM
    EagleBlood
    Did you try doing it with S Beam off? The GS3 may be getting confused. Also, is the GS3 running Jelly Bean?
  16. Thread Author  Thread Author    #16
    Her GS3 is still running ICS and when you turn S BEAM off, it says that you have to have it on. I was really looking forward to using android beam because I gave my wife a 16 gig SD card out of my old phone right before I got my N4.
  17. #17
    You can turn off s beam then turn on android beam, they are two separate things. However, ICS doesn't support transferring pics or videos through android beam. That feature came with jelly bean.
  18. Thread Author  Thread Author    #18
    Thanks. So what does android bean support on ICS then?
  19. #19
    alc2077's Avatar
    Posts
    Global Posts
    41 Global Posts
    Make sure when trying to send pics via NFC that you do it via the native picture gallary app that came pre-installed on the phone and not from a 3rd party pic gallery app. This may help, at least that worked for me
    Thanked by:
  20. #20
    Posts
    ROM
    EagleBlood
    Default
    Links and contacts from what I can remember
  21. Thread Author  Thread Author    #21
    We can forget this post. Watched a video on YouTube from android central and they say you can't send pics and videos to a Samsung phone because SBeam uses WiFi direct to transfer files instead of Bluetooth.
  22. #22
    Posts
    ROM
    Mine works fine with a Droid DNA and a Razr M. Both on 4.1.
  23. #23
    Quote Originally Posted by Jnorton2724 View Post
    I beam stuff all the time between my Nexus 4 and Nexus 7. Never had a problem so it has nothing to do with them having to be the exact same type of device. Very strange...
    Sent from my Nexus 4
  24. #24
    Caution NFC may not function properly with the use of a 3rd party battery. To ensure functionality, only utilize the Samsung designed battery with Near Field Communication printed on the battery label.
  1. Need some help with a Case
    By AAFD in forum Motorola Droid
    Last Post: 01-10-2010, 08:12 PM
  2. NOOB needs some help
    By jbg21 in forum HTC Droid Eris
    Last Post: 01-03-2010, 07:40 PM
  3. Odd place to ask, but I need HW help! Probability stuff
    By mkashen in forum The Android Central Lounge
    Last Post: 12-17-2009, 06:08 PM
  4. need some help/advice
    By medroid in forum Motorola Droid
    Last Post: 12-07-2009, 01:01 AM
  5. New Hero needs some help.
    By wolfhound89 in forum HTC Hero
    Last Post: 11-21-2009, 05:04 PM
