sidamos
Isn't it possible that those N4, that cracked without real interference by the user, are probably badly assembled? Maybe with stress on the glass?
Lol, okay, keep shaking your head. Yes, I read the paper. It isn't about glass breaking without external force. Since when is fire not considered an external force???? And the article is talking about how hot glass has to get in order to break just from the heat (or the top and bottom temperature differences on a window glass), vs. breaking or cracking due to temperature differentials between surfaces and something drawing heat far more quickly from one surface than the other. These are two different things. The primary reason a whole surface is different is because there is a lot bigger surface area (hence the term) to cause the conflict.Did you read the scientific research that I provided? Goes into pretty good detail about the temp difference required for glass to crack with no external force.
And then when I point out even more variables that we can't possibly know you ignore that. Smh
Sent from my HTC One X using Tapatalk 2
Not sure why this matters. The glass back on Apple's iPhone 4/4S cracked too. There was just as many complaints about it - especially in communities where it is intensely followed, and the truth again was that it didn't just spontaneously crack. I have two close friends who own iPhone 4S's. They don't use cases, just take care of their phones. They haven't cracked their front or back.My question is what is so different between the N4 glass and the glass on an Apple?
Addressing the paper, one more time, air is NOT granite. The temperature difference required to crack glass with AIR on each side would be MUCH bigger than required if one side was granite and the other side air. Please look up a comparison of specific heat between air and granite. I will guarantee you that if a room was on fire, and the window glass was covered on the outside by stone cold granite, it would crack WAY faster than if it was just air outside, as is usually the case. It ISN'T just about temperature differences. It is also about how fast heat is drawn/transferred to this thing on surface. This is a critical difference you ignore, and seem to think that all temperature differences, regardless of material in contact, are created equal. They are not.
This is why I asked you to look up specific heat. Speed of temperature change matters because that is what determines how fast each surface of the glass expands or contracts. With cold granite, heat moves off of the surface faster than glass' conduction ability can compensate in spreading the heat from the other side. Granite simply robs the surface in contact of the heat too fast, making that side of the glass contract much faster than air would (which is presumably on the other side). Try it. Heat up a piece of glass in the microwave. Wave it in the air. Nothing is going to happen. Now put that on a stone cold granite counter top. Watch it crack.I figured you would say that. Temperature difference is exactly what we're talking about. Explain how the speed of the temp change matters. If they difference is only ~40-50 degrees then why would it matters if it takes 1 second or 10 seconds to get there?
Here's another easy way to understand why specific heat matters. Freeze some butter and water in your freezer (ice) - each enough to fill a container of the same size. Same temperature. Take them out. Stick one hand into the ice bucket, and the other into the butter bucket (cube up the butter if you want). You will notice that the hand in the ice bucket "feels" much colder than the one in the butter bucket. Why? Both are the same temperature, and your body temperature is the same! So why would it feel different? Because water/ice has a higher specific heat and drawing heat from your hand much faster.
They are resistant, not immune to thermal pressure. There's a difference. Unless you know a granite counter top maker that will guarantee that your Borosilicate won't break when placed on it, and if it does, they will replace the top free of charge.Bottom line, GG and GG2 aren't going to suffer from thermal shock due to being put on a cold granite surface. Sorry my reply took so long, I had to find places that stated this in plain language (i'm not a scientist and can't understand all the formulas and such).
you are still talking about glass, but try this with glass with some tension from frame and it will crack. same happened in my car with front window...
I just don't understand why some of you trying to prove that we are wrong... we know what happened with our phones, not you...
But be that as it may, I am trying to get what your point is - that it is *impossible* (as opposed to simply unlikely) for this phone's back to crack due to thermal pressure? And if so, the people who are reporting that the glass cracked without them dropping it ... are they (you suspect) lying/didn't notice something happening/what? I am not saying that any of that isn't happening. It's entirely possible that someone hit their phone against something and didn't notice anything, but later when they noticed it, it became a "spontaneous" crack. I think we have discussed the thermal science (and I *do* understand the equations in scientific articles), but why did we just argue about this? Are you under the impression that I think Nexus 4's are cracking left and right because of thermal pressure? If it is, that's not a correct impression. I'm simply stating it's possible, not that it's commonplace or likely.
Is it possible that the cracking is caused by the pressure from squeezing the device when pushing the power or volume buttons?
You guys can argue all you want about what causes the glass back to break, but you better believe that it DOES break.
