Page 1 of 4 1234 LastLast
Results 1 to 25 of 79
Like Tree41Likes
    Default LG Nexus 4 Experiencing Cracking Problems Due to Glass Backing
    boy hope they resolve it with the newer batches... ordered mine on the 27th.
  2. #2
    Default Re: LG Nexus 4 Experiencing Cracking Problems Due to Glass Backing
    I notice that article gave no sources for any of their claims.
  3. #3
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    I notice that glass breaks because the rules of physics are still in place. Drop your phone, bad things happen. Put it in a case and don't be sloppy. Anyone who says their glass spontaneously broke is trolling.
  4. #4
    Ziptied's Avatar
    Your Resident Googler
    Posts
    Global Posts
    766 Global Posts
    ROM
    Stock
    Quote Originally Posted by gone down south View Post
    Because its total BS.
    Google it.
    Ry, sonicresidue and celliott96 like this.
  5. #5
    Citizen Coyote's Avatar
    Posts
    ROM
    JB 4.2.2/GB 2.3.4 w/ root
    Quote Originally Posted by donm527 View Post
    News flash: glass breaks. Also, water is wet, and can damage electronics.
    The author said his Nexus 4 and LG Optimus were not dropped. Just temp change caused the crack.
    Quote Originally Posted by 2defmouze View Post
  8. #8
    Jerry Hildenbrand's Avatar
    AC Cowboy
    Posts
    Global Posts
    5,807 Global Posts
    ROM
    Homebrewed
    "Nexus 4 and LG Optimus G back doesn't have a cracking problem"
    -- source, everyone else.
    Thanked by 2:
  9. #9
    YoSaintLaurent's Avatar
    Posts
    ROM
    EagleBlood
    The issue with the droid-life article is it makes you think it is a quality issue when it is really a science issue. Cold granite and warm glass don't mix. Even more so with cold and moist granite. The same thing happened with you put a warm Pyrex dish on a granite counter tops. It is one of the downsides of granite.
  10. #10
    I call BS on this article. Am I the only one? The temperature difference is not THAT extreme. Pour boiling water into a glass and put it in the freezer - THAT will cause the glass to crack. This won't.
    Honestly, I do not understand why so many people are so quick to believe unsubstantiated claims.
  11. #11
    Posts
    ROM
    EagleBlood
    Default
    Quote Originally Posted by sonicresidue View Post
    Google "granite countertop Pyrex." You will find a lot of articles about how placing a hot glass on cold granite causes it to break. Given that the glass on both phones are nowhere near as thick as a glass container it wouldn't be unreasonable to think that it would crack if placed on it. I know my Nexus 4 gets pretty hot after long periods of use. I also know after seeing those pictures I will not be leaving my phone anywhere near granite countertop!
  12. #12
    How cold was the counter top? Not very.
    I still say it's nonsense. Some of you people will believe anything.
    Thanked by:
    Jerry Hildenbrand likes this.
  13. #13
    Several and many very scientific descriptions there. The back is glass that means the phone has 2x the possibility of breaking. I've had a phone with a all glass front for 3 years and never broken the glass once. So 2x times 0 = 0, I don't see the problem.
  14. #14
    my N4 back cracked today, never dropped... this is not a BS... BS is that google sell this phone with this issue...
    captain_haddock likes this.
  15. #15
    Quote Originally Posted by AnGeor View Post
    Can you be more specific? When did it crack, how did you find out it cracked, where was the phone immediately prior to cracking, did you set it down on a cold granite countertop after use? Something has to have caused the crack. Glass doesn't just crack on its own.
  16. #16
    Ziptied's Avatar
    Posts
    Global Posts
    766 Global Posts
    ROM
    Stock
    It's BS that your phone randomly broke, unless simultaneously all the glass in your house, including windows and mirrors, and car glass shattered at the exact same time. see how unlikely it is.
    Google it.
    nixie21 and bobjohnson201 like this.
  17. #17
    Kevin O'Quinn's Avatar
    Posts
    Global Posts
    7,674 Global Posts
    ROM
    Stock
    Glass doesn't spontaneously break. Something causes it. Even flexing slightly can.
    So no, it didn't "just happen" something caused it to happen.
    Sent from my HTC One X using Tapatalk 2
    Forum Rules & Guidelines -- CLICK HERE
    I'm an NVIDIA Tegra Champ. Here's what that means. It means that from time to time I might receive products and/or services from NVIDIA to evaluate them and provide feedback to NVIDIA and you, our valuable members. What this does NOT mean is that my opinion will be biased. Any opinion that I express here and elsewhere are solely based on my personal preference and any relevant expertise that I may/may not have on the subject matter.
  18. #18
    as always everybody know what happened to MY phone better than ME...
    Yea, something caused it, I'd say too much tension and temperature change. Maybe it was too cold outside today? It was in my pocket, email arrived with vibration notification. I was outside, checked the email and put it back. Another email and when I reach for it, I can feel the crack. I was standing outside, smoking... So something caused it for sure, but it wasn't me... Maybe the vibrations are too powerful?
  19. #19
    Did you check the back before/after the first email arrived and made sure there wasn't a crack? Isn't it possible that something caused the crack long before you went for a smoke but you didn't notice it till later?
    No one is claiming they know what happened to your phone better than you. But glass does not just crack or break spontaneously. There has to be a better explanation than "I put it in my pocket and it magically shattered."
    Thanked by:
    KitN
  20. #20
    Posts
    ROM
    Temperature change can certainly crack glass. A few people have reported that putting their hot phone on a cold surface (such as the granite counter top noted earlier) cracked the back glass. Is it cold where you live right now? Did you go from a warm environment (indoors) to a very cold one?
    As others have noted, glass doesn't magically break; there's always a reason. Pinpointing what that reason is can help you and others avoid it later. If N4's are cracking due to environmental temperature change, that sucks and we'll have to be aware of it. Anyone know if the iPhone 4/4s suffered from breakage due to air temp changes?
  21. #21
    I have been trying to activate the cracked back feature, but after quite a few drops, the back is still intact, perhaps an OTA will fix this.
    Thanked by:
    KitN
    Citizen Coyote and CoolBeit like this.
  22. #22
    Quote Originally Posted by yfan View Post
    I'm 100% sure it wasn't cracked before, because now I can feel the crack..
  23. #23
    post a screenshot with your cracked nexus 4 + logged in on your PC with this account. side by side
  24. #24
    Granite gets pretty cold, my old house granite probably good 6cm thick (about 4 Nexus's) and on a 40 degree Celsius day it was still relatively cold presuming most of it was in the shade.
    My current granite about 2cm is pretty cold, but not as cold but if a glass or plate is hot and placed on it, I will expect it to crack very quickly.
    - - - Updated - - -
    N'oublions jamais l'Australie
    - Victoria School, Villers-Bretonneux, France
  25. #25
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Mothers last name and ss number too?
    Does it matter? Glass cracks and the n4 is glass
    Sent from my X-Band Modem... TY Genesis
    bobjohnson201 likes this.
  1. anyone have their nexus 4.2 freezing due to apps?
    By runningman3433 in forum Google Nexus 4
    Last Post: 11-28-2012, 10:23 AM
  2. New Nexus 7 with the backlight problem - how to set it up?
    By cskilbeck in forum Google Nexus 7 Tablet
    Last Post: 10-04-2012, 05:37 AM
  3. Have my second Triumph, about to get a third due to more problems
    By bvans in forum Motorola Triumph on Virgin Mobile
    Last Post: 07-28-2011, 11:20 AM
  4. LG Optimus V Recall Due to 3G Problems?
    By DaveSin in forum Virgin Mobile Optimus V
    Last Post: 06-20-2011, 11:49 AM
  5. ok... exchanged due to defective lcd.. new problems to replace it..
    By hurang in forum Verizon HTC Thunderbolt
    Last Post: 03-23-2011, 12:35 AM
