Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By gone down south
    Default Android OS process consuming 3 times more battery power than the screen
    I got a Nexus 4 on the Friday of release week. I love it! I do have one concern:
    I've been seeing my battery dropping faster than I would like, without what I would consider an abnormal amount of use. The main culprit in my battery stats is Android OS. It has been consuming much more than my screen - today almost three times as much! And this has been the case for much of the time I've had the phone.
    Today I've had 55 minutes of screen on time and it was down to less than 49% just after lunch, when I plugged it in briefly. I have my screen brightness set to 0 (not auto). I have my location tracking turned off in Maps, some of the location features in Google Now disabled, and I've been connected to stable wifi almost all day. My phone signal here at work is stable at four bars.
    I have the default launcher, default keyboard, and just standard apps like Twitter and Instagram installed. I don't have Facebook installed.
    Any ideas what would be causing Android OS to be using this much power? Or is that number misleading, and this is normal? I don't feel like I'm using the phone all that much, for it not to at least get me through most of the day.
  2. #2
    Default Re: Android OS process consuming 3 times more battery power than the screen
    My screen uses more
    Attached Thumbnails Attached Thumbnails Android OS process consuming 3 times more battery power than the screen-uploadfromtaptalk1354232624233.jpg
  3. #3
    Quote Originally Posted by mattatwar1 View Post
    My screen uses more
    Mine too.
  4. #4
    It's a new phone, give it a week to settle in before you start freaking out.
    digitalslacker likes this.
  5. #5
    danimal62's Avatar
    Posts
    Global Posts
    55 Global Posts
    Mine used more today but it got the update it hasn't been. Maybe that's what happened.
  6. #6
    My Galaxy Nexus on 4.2 is also having battery issues. It doesn't always disconnect from the GPS which remains running and earlier today "Google Services" used 46% of the battery. It is also slow to charge, I did not have these issues before upgrading the OS... I have to reboot the phone to resolve.
  7. #7
    Kaenon's Avatar
    Posts
    Global Posts
    233 Global Posts
    Quote Originally Posted by shmandroid View Post
    I had this too.
    Then I got my 16GB version in today and no issues.
    I will try to look into the issue more and see if I can figure out a solution.
  8. Thread Author  Thread Author    #8
    I'm not freaking out - just curious! I'm happy with the phone either way. But I'm a nerd and I like to study and discuss these types of things!
    @tjm9007
    Cool - let me know what you find out. The first couple days I noticed the Mediaserver process was taking up more than screen or Android OS. I turned off syncing on Google Music, reset the phone, and that seemed to fix it.
    I wonder if it could be Google Now constantly checking on things? Maybe I'll disable it for the day and see if anything gets affected. I'll let you know!
  1. Do animated widgets use more battery power?
    By Ophio in forum T-Mobile Galaxy S3
    Last Post: 08-29-2012, 06:02 AM
  2. Android OS using a ton of battery
    By Atranox in forum Droid RAZR MAXX
    Last Post: 03-12-2012, 07:49 PM
  3. Android OS keep awake time
    By xweb10 in forum Verizon Galaxy Nexus
    Last Post: 01-21-2012, 07:54 AM
  4. No more ring to unlock the screen?
    By Hydraulic Jack in forum HTC EVO 3D
    Last Post: 09-10-2011, 03:08 PM
  5. display uses more battery power
    By drummerman2008 in forum Verizon HTC Thunderbolt
    Last Post: 05-09-2011, 12:12 PM
