Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By DirkBelig
    fam617's Avatar
    Posts
    Global Posts
    30 Global Posts
    Default Nexus 4 In Call Volume too LOUD!
    Got my N4 16GB device last night and hooked it up with ST (with TMobile SIM). When talking on the phone the in call volume is unbearably loud! I have it all the way to the lowest volume setting using the volume rocker and need to hold the phone away from my ear b/c it is too loud.
    Is anyone else experiencing this..heard of this?
  2. #2
    DirkBelig's Avatar
    Posts
    Global Posts
    1,293 Global Posts
    ROM
    Stock
    Default Re: Nexus 4 In Call Volume too LOUD!
    Quote Originally Posted by fam617 View Post
    I was going to post, "Use the volume control, n00b!" until I got to this part. Perhaps you've become a vampire or Spider-Man and have super-hearing now?
    "The Nexus 4 is such a big black slab of power that if you dropped it down in the middle of a pack of monkeys, they'd start using weapons." - Dirk Belligerent.
    palitsyn likes this.
    fam617's Avatar
    Posts
    Global Posts
    30 Global Posts
    I know it sounds crazy...just had co-workers try it out and they say the same - too loud for them too.
    fam617's Avatar
    Posts
    Global Posts
    30 Global Posts
    Found a fix...raised the volume to the max setting and then dropped it back down. This did the trick. Seems like a bug, Google?
  5. #5
    Its always loud here, especially where I work, what's loud in my apartment is perfectly balanced output outside. This is the best metropolitan phone I've had.
    One bug I've noticed is the phone immediately dropping to silent and vibrating, displaying a gray speaker icon with a slash through it in the notification area. I don't know how to replicate it. Holing the volume rocker until it changes to vibrate mode displays a white, shaking phone icon in the notification area instead so I have no idea what setting is kicking in. Thank God it happens rarely but it has happened while in my hand, too. Quite odd.
    •°•NEXUS 4•°•
  6. #6
    could it be on speaker?
    Galaxy Note II 16GB white unlocked and Galaxy Note 10.1 grey version GT-N8013 not rooted
    Linux user #449322 running Linux Mint 13 KDE
  7. #7
    Raising volume to max (using rocker) while in call then lowering it worked for me too.
  8. #8
    Weishaupt's Avatar
    Posts
    ROM
    Stock
    I can second that with the two Nexus 4 I have (the first and its replacement for earpiece buzz). Its extremely loud. Is there any ticket on Google Code?
  9. #9
    My earpiece buzzes like a mother. It's borderline unusable. I've had to end calls and tell people I'll just have to text them back. I get ticking noises that come through randomly as well. I want to send it back.
  10. #10
    Quote Originally Posted by anothernewphone View Post
    Lol sounds like you've been tapped
  11. #11
    I called Google support at 855-836-3987. They say my unit is defective and they are replacing it for free.
    Great phone!
  12. Thread Author  Thread Author    #12
    fam617's Avatar
    Posts
    Global Posts
    30 Global Posts
    Yes...that's what I did. New phone came in 2 days and had no issues with buzzing.
  13. #13
    The call volume issue (not the buzzing) is logged as a bug here:
    I have the same problem and can confirm the workaround mentioned above (turning the volume all the way up, then down again).
  1. Verizon G-Nex In-call volume too loud
    By Major517 in forum Verizon Galaxy Nexus
    Last Post: 12-04-2012, 09:22 AM
  2. Wired headset volume too loud for calls
    By kimberlyinmn in forum Virgin Mobile Optimus Slider
    Last Post: 02-24-2012, 08:22 PM
  3. In-Call Volume Too Low Not Going Up...
    By AisforAustin in forum Motorola Droid 2
    Last Post: 06-07-2011, 07:54 AM
  4. Rooted. Call volume too loud. Is there a way to change volume range?
    By DigitallyChallenged in forum Verizon HTC Thunderbolt
    Last Post: 05-13-2011, 09:55 PM
  5. In-call volume too low on Evo 4g
    By gary11082 in forum HTC EVO 4G
    Last Post: 09-15-2010, 05:24 PM
