12-11-2012 11:39 AM
29 12
tools
  1. Phenom's Avatar
    I've been using Google Voice + Groove IP for the past week on T-Mo's $30 plan and haven't had any real issues. When I tested it myself over WiFi (w/ my GS2), there was major lag but when I called my wife, she said she didn't notice any delay. Of course that was over a 30mbps connection, so I still need to try on the T-Mo network. But if this month long trial goes well, I'll be ditching Sprint...well, sorta. Wife still has a year on her contract.
    12-10-2012 05:14 PM
  2. 6tr6tr's Avatar
    Have you tried it over a data connection yet? How was it? After your calls, can you also test the up/down speeds in speedtest?
    12-11-2012 11:03 AM
  3. yfan's Avatar
    I use Talkatone, and my experience with it seems to be different from most here. I actually find Talkatone having much less delay issues than GrooveIP. Either way, I have used Talkatone both over wifi and T-mo data, and wifi is definitely better, but that's mainly because of the latency issues with mobile data. It does work pretty well over a data connection though. I haven't got to test on all different kinds of speeds, since I almost always get an HSPA+ connection with T-mo.
    For outgoing calls, I have also tried using the Vonage Mobile app (and registered my GV number with it), and on quality, it beats the pants off of Talkatone, GrooveIP, etc. It's 3000 minutes free per month, but only works for outgoing calls.
    All this being said, I don't use minutes all that much anyway. The vast majority of my communications over the phone is through texting or chat applications. My guess is that if I were to use no VoIP app, I would still have a pretty hard time going over 100 minutes on most months.
    12-11-2012 11:30 AM
  4. 6tr6tr's Avatar
    Thanks for the info!
    The problem with GrooveIP is that it only has one quality/codec setting, so it takes about 1.2mb per minute of talk. The other VOIP apps can adjust for (or default to) lower bandwidths. I found that sipdroid doesn't adjust well, but if you manually change it to a lower codec (like speex 11kbit) it works well on a very slow connection.
    Have you tried the one free call to a phone from Skype? I'd like to know how it compares to Vonage quality.
    12-11-2012 11:39 AM
29 12
  1. Help! looking how to get free mins using google voice of VOIP
    By Aruen91 in forum Virgin Mobile Optimus V
    Last Post: 04-12-2014, 09:40 PM
  2. [GUIDE] Free VOIP using Google Voice and Groove IP
    By Takenover83 in forum General Help and How To
    Last Post: 04-18-2013, 10:12 PM
  3. data allotment to use google voice?
    By js6218 in forum AT&T Inspire 4G
    Last Post: 01-18-2013, 11:50 AM
  4. Can I use Google Voice over WiFi, not Cell Service?
    By chrislitzkow in forum Android Apps
    Last Post: 09-14-2011, 01:59 PM
  5. Anyone using Google Voice?
    By pjs2004 in forum AT&T Captivate
    Last Post: 07-23-2010, 05:00 PM
