07-18-2013 01:39 AM
182 12345 ...
tools
  1. badbrad17's Avatar
    Bad?! Take a screen shot when you hit 4hrs+, I don't think I believe the device can come close to it. I'm not arguing with you or anything, but 3hrs is solid as far as on screen times go; anything over 3 is just gravy.
    Totally doable but you need to turn gps off unless it's needed.
    TheLibertarian likes this.
    12-23-2012 07:19 PM
  2. Dr0me's Avatar
    great tip to save battery!!!
    I recently got a new work email app that causes me to use a pin or pw instead of the pattern draw to unlock. to prevent how often i had to input this, I changed the setting. time before locking after phone screen turns off to 30 min and noticed some SERIOUS battery drain. I figured out it was that setting keeping the phone awake until the 30 min after i used it and it finally locked and slept. I turned the setting to 1 min and it completely fixed the problem. Using anything except a low setting will give you awful drain and will show as android OS on the battery stats page.
    badbrad17 and tn_friend like this.
    12-23-2012 07:24 PM
  3. Bazinga11's Avatar
    When I first got my phone, for the first few charges my battery was horrible. Now it is much better but I also switched carriers (before I was barely ever getting reception) I think that also plays a part in drainage because the phone is always trying to connect to the network. RIght now it is at 11% 15h and 30m with 3h 27m screen time.
    badbrad17 likes this.
    12-24-2012 12:12 AM
  4. peejay1977's Avatar
    I think the key to Android is the to treat it like a PC or Laptop, you have almost unlimited control over what you can do and you need to take responsibility for what you install and configure, then it makes perfect sense. Also some people say what's the point in having all these features if you can't have them on in case they drain battery but from my point of view its no different than a brand new PC, work recently bought me a shiny HP Ultra book laptop and its great, BUT I uninstalled most of the preinstalled HP crap and turned off a lot of the services bloating the OS, runs much better now. I treat Android the same way.
    12-24-2012 06:03 AM
  5. Grizzle34's Avatar
    Try deep sleep battery saver works amazingly well.
    12-24-2012 08:51 AM
  6. Plano26's Avatar
    Here is how I did for the last charge; I wish I knew why "Mediaserver" is taking up battery life. I do have GPS off and no location sharing (which I don't use anyway) I'm pretty happy with this
    12-24-2012 10:35 AM
  7. KwietStorm's Avatar
    It's not the battery life when my phone is off that bothers me. It's just that when I can visually see the percentage points dropping in realtime while the screen is on, it makes me feel like something isn't optimized properly in 4.2. Also a question, is it possible to flash a kernel to your phone without flashing an entirely different ROM?
    Attached Thumbnails The so called Nexus 4 battery woes-uploadfromtaptalk1356424738132.jpg   The so called Nexus 4 battery woes-uploadfromtaptalk1356424760134.jpg   The so called Nexus 4 battery woes-uploadfromtaptalk1356424793120.jpg   The so called Nexus 4 battery woes-uploadfromtaptalk1356424803837.jpg   The so called Nexus 4 battery woes-uploadfromtaptalk1356424813619.jpg
    12-25-2012 02:45 AM
  8. badbrad17's Avatar
    So are you not happy with those numbers? That looks great in my books. I got 16 hours today with over 4 hours screen time. And still have 20% left. It's all I need to get through the day.
    12-25-2012 03:16 AM
  9. Bazinga11's Avatar
    So what would you guys say is the average screen time for the nexus 4 stock? I usually get around 2.5 to 3.5 hours on auto brightness, less if I play a lot of games. This is my first android phone so is it easy/worth it to root it to improve battery life?
    12-25-2012 07:01 PM
  10. sonicresidue's Avatar
    That's about what I have experienced. The most screen time I have had is 3.5 hours on my last charge. Total battery life was close to 40 hours.
    12-25-2012 07:04 PM
  11. corance's Avatar
    I just dont see how you guys are doing it. I have like 7 or 8 apps installed. I have almost every auto sync turned off and the only things set to sync under Google Account are calendar and contacts. Today i only got like 9hrs with screen on for not even 3hrs. What the hell is going on? I'm using franco kernel on stock. Could that be the issue? How do i flash back to stock kernel?
    12-25-2012 07:12 PM
  12. VertigoM's Avatar
    Turn off GPS.
    12-25-2012 07:27 PM
  13. corance's Avatar
    Well yeah that's always off. And screen is on auto btw.
    12-25-2012 07:29 PM
  14. VertigoM's Avatar
    Sure, here you go. And this was with plenty of video streaming.
    12-25-2012 08:59 PM
  15. Bazinga11's Avatar
    Does anyone know what media server is? I don't use this and I can't find this in settings and yet it takes up 13% of my battery...
    12-25-2012 10:29 PM
  16. badbrad17's Avatar
    Everything is relative to what you do. My tablet burns battery if I'm playing a game that is really taxing on the CPU. But can last for days if I am just surfing and streaming music here and there. I am getting 4 hours of on screen time and 14-16 off charge. I would consider myself a medium to heavy user. I feel like I am constantly on my phone. But I am on this forum more than I am playing games, so that may make a big difference. What I do know is that compared to my SGS2 I know I could go out for the evening with 60% and not be worried that I would run out. I would never make it on my SGS2 unless I had everything turned off.
    12-26-2012 01:15 AM
  17. Bazinga11's Avatar
    Do you have any of the mods that other people are using to get 4 hours of battery life. I don't know if my battery is defective or not lol I only have a few more days if I want a replacement.
    12-26-2012 01:05 PM
  18. sonicresidue's Avatar
    I find it takes a few charging cycles for a the battery to improve. My battery life has been steadily improving over the last couple weeks. I was able to manage 4 hours of screen time with 28 total battery life with this past cycle. Mostly internet, Facebook, online news apps, texting and phone calls. No heavy media usage or games.
    12-26-2012 04:01 PM
  19. SteveMW's Avatar
    Try turning GPS back on. Whatever app (FB?) that is trying to read you GPS position may be causing the high readings.
    Sent from my Kindle Fire using Android Central Forums
    12-26-2012 04:25 PM
  20. badbrad17's Avatar
    What do you mean by mods?
    12-27-2012 12:42 AM
  21. Shadow_33's Avatar
    I'm increasingly finding Android's multi-tasking without much use. The apps that "need" to run in the backround are usually needlessly draining the battery, such as Twitter, Pulse, etc. Unless you are actually reading every news feed, or every tweet, there's really no need for the
    multi-tasking. I would gladly give it away, if it would make my cell phone stay charge for a whole day even with heavy use.
    The only app I need running is the one I'm actually using. Android allows apps to just "wake up" and start doing God knows what in the background.
    12-27-2012 04:43 AM
  22. Tabs85's Avatar
    The option that seriously improved my battery life was stopping auto sync on everything using the control settings app. Serious improvements! just switch on sync when you need to check your emails etc etc.
    12-27-2012 06:05 AM
  23. Avenger's Avatar
    I found it got better after a few days use. It also helps to load custom firmware and a good kernel.
    12-27-2012 10:52 AM
  24. badbrad17's Avatar
    I'm running stock, but rooted. I decided to not plug in last night just to see how the sleep mode was and how long I could go and I think that this is where this phone shines. It uses nothing in sleep mode. I only lost 3% over night. I am truly blown away by this battery and can only say that if you are not getting a full day with 4 hours of on screen time you should send yours back for a new one. I use my phone a lot and am shaking my head on how long it lasts. If Google makes it better with updates then I will be a happy camper.
    12-27-2012 11:38 AM
  25. DeadpoolJunior's Avatar
    Well, yesterday I got about 3hrs on screen time but at the risk of my battery only lasting 9hrs by the time I hit 10%. Today, with light usage (Twitter, News Readers, Texts, Emails) im at 68% after 5h 33m 39s on Battery (Screen on is 1h 5m so far). I wouldn't say thats amazing, its pretty decent, wish I was getting the numbers you all are getting though. badbrad17 mentioned over night, he only lost 3%. Thats amazing, because when I put my phone off all night I lost maybe 10% which is good but not 3% great. I think how long your phone last overnight when its asleep is a good indicator of how long it'll last real world. When my Gs2 had battery issues (like lasting maybe 5-8hrs on a charge), itd go down maybe 30% over night or more. Oh well, guess this is the battery life i'll just have to live with without gutting my phone and rendering it useless by disabling every key aspect of it just to get an extra hour or so. I have 46 apps, so maybe i'll trim that down a bit and see how it goes.
    12-27-2012 12:31 PM
182 12345 ...
  1. Anybody get the so called OTA update for ICS?
    By vickery1956 in forum Verizon HTC Rezound
    Last Post: 08-27-2012, 12:14 AM
  2. Aluminum battery door for the Verizon Galaxy Nexus (i515)
    By Linebarrel86 in forum Verizon Galaxy Nexus Accessories
    Last Post: 08-07-2012, 03:38 AM
  3. So is this the official new Nexus phone?
    By AllenRulz in forum Sprint Galaxy Nexus
    Last Post: 01-17-2012, 12:31 PM
  4. Will the Samsung Epic 4G battery fit the Samsung Nexus S?
    By KillerQ in forum Sprint Nexus S 4G Accessories
    Last Post: 09-06-2011, 12:30 PM
  5. The so called "Web Cam?"
    By RealFnCool in forum Motorola Xoom
    Last Post: 03-21-2011, 06:10 PM
