Page 5 of 8 FirstFirst ... 2345678 LastLast
Results 101 to 125 of 182
Like Tree28Likes
  1. #101
    TheLibertarian's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: The so called Nexus 4 battery woes
    Quote Originally Posted by DeadpoolJunior View Post
    Is there a reason you have Twitter syncing every 15 minutes?
    ...because I'm a Twitter junkie lol. I know what you mean about Facebook, I'm hardly on it, I just have it syncing so often since a fair amount of friends use much more frequently than I to communicate, etc.
    What do you average for on screen time?
    EDIT: I'm also not super concerned with battery life. Would I like 20+ hours and 4+ hours on screen time? Absolutely. But I prefer to not inconvenience myself just for the sake of delaying the inevitable charge a short while longer. If I have to charge it a bit more, then so be it. I'm usually also able to have my devices charging if need be.
  2. Thread Author  Thread Author    #102
    peejay1977's Avatar
    Posts
    Global Posts
    199 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Have to say I surpassed myself yesterday, managed 30hours with still a few percent of charge, nearly 4 hours screen time. Everything turned on, no voice calls I must confess but plenty of browsing, emailing, Facebooking etc and always on WiFi. I'm adamant being on the cellular network especially if the signal is poor is one of the biggest drains.
  3. #103
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I also want to say it wouldn't shock me if some batteries were just plain better than others; could almost go so far as to say defective.
    The disparity is so vast between every reviewer and consumer it makes you wonder if something could indeed be faulty here.
  4. #104
    DeadpoolJunior's Avatar
    Posts
    Global Posts
    287 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by clayjohn View Post
    Average screen on time I get is 2.5 hours with around 12 hours total.
    TheLibertarian likes this.
  5. #105
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    I agree.
  6. #106
    DogPsyche's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by peejay1977 View Post
    Can I ask whether this is with mobile data on or off?
    Sent from my Nexus 4
  7. Thread Author  Thread Author    #107
    peejay1977's Avatar
    Posts
    Global Posts
    199 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by DogPsyche View Post
    On, I went to London on the train recently and the signal was in and out constantly and it absolutely killed the battery. Used to do the same on my iPhone too.
  8. #108
    Bazinga11's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My battery is weird, sometimes it stays at a percentage for a bit and I think its finally stable. Then it goes does down like 3-5% in a few seconds while im just on the home screen. I ordered a replacement today, hopefully it doesn't have the same problem.
  9. #109
    DogPsyche's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do you think it'd make much of a difference with mobile data turned off?
  10. Thread Author  Thread Author    #110
    peejay1977's Avatar
    Posts
    Global Posts
    199 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Possibly, but I think its more likely to be the radio going from full signal full 3G to no signal, to partial signal burn only 2G and so on and so forth. I always found on my iPhone if I was travelling to London it was better to force it onto 2G that way it didn't keep messing about constantly, the battery was better and the signal stayed more constant. Even if the data speed was a lot slower.
  11. #111
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    I turned on Google now for the first time yesterday and noticed a significant difference in battery drain. You may want to try turning that off if you are not using it
  12. #112
    nrm5110's Avatar
    Posts
    Global Posts
    831 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by badbrad17 View Post
    Dude I dunno why you guys have to sacrifice so many features to get decent life.
    Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
  13. #113
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Quote Originally Posted by nrm5110 View Post
    I have had great battery. I just noticed that GNow used more so I am just trying to help people who haven't been able to get what I have.
    TheLibertarian and nrm5110 like this.
  14. #114
    PhilSterBoy's Avatar
    Posts
    Global Posts
    67 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just installed juice defender ultimate and turned off the map setting. Hopefully I see an increase
  15. #115
    nrm5110's Avatar
    Posts
    Global Posts
    831 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by PhilSterBoy View Post
    I can promise you its terrible and won't help like you are hoping
    Here Juice defender?
    pontiac005 likes this.
  16. #116
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Ya not really sure it helps much.
  17. Thread Author  Thread Author    #117
    peejay1977's Avatar
    Posts
    Global Posts
    199 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I installed Juice Defender but even on the most conservative setting it was disabling mobile data while I was out so I missed emails and push notifications. Decided I could do a better job myself lol
  18. #118
    mawil1013's Avatar
    Posts
    Global Posts
    2,558 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I agree 100%, Apps are the major cause of battery drain IMHO. Some people are App collectors, dumping one App after another regardless of whether they are really needed or even used. My personal criteria is any App going on my phone must be something That I'll actually use at least 3-4 times per month. A lot of times I look to see if I can access the same function of an App by going thru the Web browser then setting a book mark. Such as I won't use Fandango App on my phone but use Google search for a book mark to my local theater or go directly to Fandango Web Site.
  19. #119
    andrewppurdy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have to agree that the battery gets better with time. But as well as this I have turned something's off, for example I struggle to get a HSDPA + connection so I have limited it to edge. As well the screen is on about 15%. No battery monitoring is installed.
    These are photos from over two days.
    Day :1
    Day 2:
    For both days I have listened to a lot of music, streamed BBC iPlayer and YouTube as well as check Google plus.
    Sent from my Nexus 4 using Android central Forums
  20. #120
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    No one could ask for more than that.
  21. #121
    GopherDroid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How do you stream YouTube if you're on edge? Won't that take like 30 minutes to buffer a 5 min video?
  22. #122
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Most of the time I had WiFi on. But I did allow 3g networks on day 2; where I streamed BBC iPlayer for 45 minutes
  23. #123
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I mean that I allowed 3g at the end of the cycle, and not all the way through
  24. Thread Author  Thread Author    #124
    peejay1977's Avatar
    Posts
    Global Posts
    199 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm giving CyanogenMod 10.1 a go. We'll see what difference if any it is
  25. #125
    Dalton Dumptruck's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have no issues with this battery. I have gps, wifi, and mobile data enabled and use it for Web browsing, Facebook, Twitter, Pulse, and a bit of Netflix and NBA Game Time on and off throughout the day.
    I've had this phone for two weeks now and don't regret my choice.
    Attached Thumbnails Attached Thumbnails The so called Nexus 4 battery woes-uploadfromtaptalk1357021191654.jpg
    badbrad17 likes this.
  1. Anybody get the so called OTA update for ICS?
    By vickery1956 in forum Verizon HTC Rezound
    Last Post: 08-27-2012, 01:14 AM
  2. Aluminum battery door for the Verizon Galaxy Nexus (i515)
    By Linebarrel86 in forum Verizon Galaxy Nexus Accessories
    Last Post: 08-07-2012, 04:38 AM
  3. So is this the official new Nexus phone?
    By AllenRulz in forum Sprint Galaxy Nexus
    Last Post: 01-17-2012, 01:31 PM
  4. Will the Samsung Epic 4G battery fit the Samsung Nexus S?
    By KillerQ in forum Sprint Nexus S 4G Accessories
    Last Post: 09-06-2011, 01:30 PM
  5. The so called "Web Cam?"
    By RealFnCool in forum Motorola Xoom
    Last Post: 03-21-2011, 07:10 PM
