Page 6 of 8 FirstFirst ... 345678 LastLast
Results 126 to 150 of 182
Like Tree28Likes
  1. #126
    Hubertsng's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: The so called Nexus 4 battery woes
    Got a good four hours on my nexus 4. Didnt ss it but just take my word. Wifi was on the entire time too
    Sent from my Nexus 4
    badbrad17 and Titan206 like this.
  2. #127
    Chum's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    At home all day with WiFi on. Seems pretty decent to me. I wish I had better T-Mobile signal inside my house, oh well. Any comments on these stats?
    Attached Thumbnails Attached Thumbnails The so called Nexus 4 battery woes-s1.png   The so called Nexus 4 battery woes-s2.png   The so called Nexus 4 battery woes-s3.png
  3. #128
    Lugz6002's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thought I would contribute to this thread. Here is my latest battery usage...
    This was from full charge down to 1%, using a combination of calls, texting, web-browsing for a couple of hours (using both Wi-Fi & HSPA+), 15 min HD vid on Youtube, Tapatalk browsing and more.
    Wasn't expecting massive battery life with this device, but I'm more than happy wth it considering what some reviews have stated. I'm never far away from a charge point anyway, so not a big issue for me
    John-Smith likes this.
  4. #129
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Quote Originally Posted by Lugz6002 View Post
    http://dl.dropbox.com/u/1111867/Battery_life.png
    http://dl.dropbox.com/u/1111867/Screen_time.png
    It's more about screen on time than anything. 4-5 hours is pretty normal. Your last 8 hours at the end was when the phone was idle. That's easy with any phone.
  5. #130
    Bar81's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by PhilSterBoy View Post
    Just installed juice defender ultimate and turned off the map setting. Hopefully I see an increase
    Juice defender helps with power usage during idle; it will not do anything to help power usage when using the phone.
  6. #131
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Quote Originally Posted by Bar81 View Post
    It does little regardless.
  7. #132
    nrm5110's Avatar
    Posts
    Global Posts
    831 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Actually the only thing it helps is killing signals which often can have mixed results.
    Firstly the app itself has to stay active often keeping the phone from Deep sleep mode. This causes what we call a wake lock.
    Second if you have poorly written apps that poll regularly that app may have issues and cause worse drain. This often isn't an issue but it has happened.
    Those apps really are nothing more than a placebo if you take the time to turn data or WiFi on and off with built in toggles (aosp based ROMs, and touchwiz I can confirm have them.) You would achieve similar if not better results.
    Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
    DogPsyche likes this.
  8. #133
    Bar81's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by nrm5110 View Post
    Okay, I will uninstall and see what happens and report back.
  9. #134
    PhilSterBoy's Avatar
    Posts
    Global Posts
    67 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I installed juice defender ultimate and my battery life has greatly improved. X1.59 according to the app but it feels like it last much longer
  10. #135
    Doooshty's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I took my phone off the charger at 4 am when I woke up, went back to sleep, never touched the phone and when I woke back up at 9am i was at 80% with ZERO screen usage. I'm thinking about getting a replacement
  11. #136
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Quote Originally Posted by Doooshty View Post
    mine only used around 5% in 8 hours.
  12. #137
    GopherDroid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Did you have alarms or other settings that would have forced the phone to wake? That's what drains the battery in such a scenario, in my experience.
  13. #138
    Evil_Munki's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My battery has died, and after 26 hours I've had 3 hours of screen time.
    I've optimized the wakelocks so the idle battery drain is as good as I can get without sacrificing Google Now etc (around 0.5-0.7% per hour)
    My screen brightness is on automatic, Franco r28 kernel, stock rom, GPS off, Wi-Fi mostly on, no video games/movies played, Google Now on.
    Is this normal? People have posted great battery life of 4 hours plus with similar set-ups it seems
    http://i.imgur.com/A15B8.png
    http://i.imgur.com/yE3RB.png
    http://i.imgur.com/78Fm3.png
  14. #139
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Quote Originally Posted by Evil_Munki View Post
    I think that is pretty normal. In reality it's just about making it through a full day with a charge at night. Most of us are getting 3-5 hours of screen time but there are so many variables that can change this. But your numbers look good. IMO.
  15. #140
    sonicresidue's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thats about where I average. If I get less than 3 hours screen time, it's because I chose to start charging before the battery was down to 1 or 2%, otherwise 3 hours is pretty obtainable. I hit 4 hours screen time ONCE but can't remember how I did it. Getting about 30 hours total battery time. Again, this is an average, sometimes more, sometimes less.
  16. #141
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    I really believe that data is the big thing as well as a poor signal. I have been using my phone pretty sparsely today as I do consider myself a power user but I am now sitting at over 12 hours with 2.5+ hours of screen time. Also streamed some music on data for about 30 minutes.
    I'm using Juice defender on basic and have everything else off as much as possible including Google Now.
  17. #142
    SimonB15's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had been getting quite good (read: acceptable) battery life out of my N4 - 16 hoursish off charge with 3+hrs screen on time, but the last couple of days have been disappointing. Today, for example, 13.5 hrs off charge, 1hr 15mins screen on time. Biggest users were Screen 26%, Andoird OS 20%, Phone Idle 13%, Mobile Standby 11%. Interesting thing in Mobile standby: Time on 13h 39m 47s, Time without signal 14%. That suggests that, over the course of the day, for close to 2 hours my phone was trying to pick up a signal.
    I'm wondering if people think this might be a cause of my problem over the past couple of days?
    I've not changed any of my sync settings, and today I even ran with WiFi turned off all day to see if there was an improvement. I use auto screen brightness and GPS turned off. I sent less than 20 texts today, Facebook had used 3% of my battery (so not much usage there with infrequent syncing), placed 2 very short (< 1 minute) phone calls, and played a couple of games (combined to about 3% battery as well).
    Sorry, no fancy screenshots as I'm writing from my laptop :-)
  18. #143
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Quote Originally Posted by SimonB15 View Post
    So were you on data? I have found it makes a huge difference if I am getting a weak data signal vs wifi. I always turn data off and only flip it on when I need it.
  19. #144
    Doooshty's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yesterday I had decided to do an RMA. I had been getting 8 hours of battery life with maybe 2hrs of screen time. I decided to give the battery a few days first. Yesterday I let the battery die, kept the phone off, and put it on the charger. I left it there for 4 hours. I then assumed it was charged. Booted into recovery and wiped battery stats. Restarted the phone and to my surprise it was only at 53%... after 4 hours. So I took it off and used it until it was about 4% then went to bed. I put it on my LG Qi charger on my nightstand. When I woke up it showed according to the charger that it was charged. Went downstairs, plugged it in and it showed 96%. I let it charge to 100 and rebooted to recovery and wiped stats again. We'll see if it makes any difference. Not sure how I was only at 53% after 4 hours of charging. This concerns me.
  20. #145
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Doesn't sound good. I've heard that the wireless chargers don't always charge to 100 percent though.
  21. #146
    Doooshty's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by GopherDroid View Post
    I'm on vacation, so no alarms. My phone drops quickly with the phone off. Even with sync, location, GPS off and screen set at min setting I still get 8-10 hours with around 2hrs of screen time. Going to RMA it I think.
  22. #147
    Doooshty's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by badbrad17 View Post
    The four hour charge was on the wall charger.
  23. #148
    Bar81's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Back to JD Plus; the increase in battery life in non-screen time is obvious.
  24. #149
    Bar81's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That is horrible; something is definitely wrong.
  25. #150
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    definitely a RMA candidate.
  1. Anybody get the so called OTA update for ICS?
    By vickery1956 in forum Verizon HTC Rezound
    Last Post: 08-27-2012, 01:14 AM
  2. Aluminum battery door for the Verizon Galaxy Nexus (i515)
    By Linebarrel86 in forum Verizon Galaxy Nexus Accessories
    Last Post: 08-07-2012, 04:38 AM
  3. So is this the official new Nexus phone?
    By AllenRulz in forum Sprint Galaxy Nexus
    Last Post: 01-17-2012, 01:31 PM
  4. Will the Samsung Epic 4G battery fit the Samsung Nexus S?
    By KillerQ in forum Sprint Nexus S 4G Accessories
    Last Post: 09-06-2011, 01:30 PM
  5. The so called "Web Cam?"
    By RealFnCool in forum Motorola Xoom
    Last Post: 03-21-2011, 07:10 PM
