Page 8 of 8 FirstFirst ... 5678
Results 176 to 182 of 182
Like Tree28Likes
  1. #176
    bobsacomano's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: The so called Nexus 4 battery woes
    Quote Originally Posted by badbrad17 View Post
    I can easily get 4 to 5 hours of screen time. Are you on data a lot? On wifi it goes a lot longer. I also am running juice defender and still toggle a little bit as needed.
    Mobile data most of the time, and I usually get full bars. The new phone just seems to have better battery life. Could be a placebo effect, but I doubt it. I am very pleased with my Nexus 4 now that I have a better unit thanks to the RMA.
    Sent from my Transformer Prime TF201 using Tapatalk HD
  2. Thread Author  Thread Author    #177
    peejay1977's Avatar
    Posts
    Global Posts
    199 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Have to say, CyanogenMod 10.1 with the Franco Kernel is noticeably better on battery life than the stock ROM.
  3. #178
    GlowyBubbles's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Haii everyone. On my Nexus 4, the Google Play Store app, Gallery, and Google Search apps have been always running. Does anyone know how to close them? (They're not "running", as in I checked the multitasking thingy and they don't appear. But apparently, they're using battery.). I want to improve battery life, so I want to close those applications. Can anyone please help? Thanks. .
  4. #179
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Quote Originally Posted by bobsacomano View Post
    that would be why. I'm on wifi most of the time which helps. Glad it worked out.
  5. #180
    moonister's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I can't help but think that the "battery industry" should get their act together because there's been little or no innovation for years. I appreciate all tips and tricks to preserve the battery but it's dreadful when you think that your device will die in 3 h if you use it properly to full extent. Also I don't quite understand why LG / Google could not fit bigger battery, they are not that big anyway. I personally wouldn't mind slightly thicker size so that I don't have to constantly worry about the juice. It actually applies to all phones not just nexus, well maybe except RAZR maxx
  6. #181
    bearlaxer321's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I love this post like its my own. I love android, but hate the struggles along with it. (My love is obviously greater) I monitor my battery usage almost everyday as it has become a habit but I also update my cyanogenmod nightly a couple times a week. There are a lot of little settings like the one you showed that can make the world of a difference. Something I just noticed that brought me to this forum was that my Samsung Galaxy Nexus's battery has a couple indents. I have seen bumps but not indents. I am probably going to buy a new battery as I dont want this to happen while I am sleeping one night:
  7. #182
    PcNy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is my battery normal ?
    Stock ROM, Unrooted, Wifi, No 3G/4G.
    Thanks
  1. Anybody get the so called OTA update for ICS?
    By vickery1956 in forum Verizon HTC Rezound
    Last Post: 08-27-2012, 01:14 AM
  2. Aluminum battery door for the Verizon Galaxy Nexus (i515)
    By Linebarrel86 in forum Verizon Galaxy Nexus Accessories
    Last Post: 08-07-2012, 04:38 AM
  3. So is this the official new Nexus phone?
    By AllenRulz in forum Sprint Galaxy Nexus
    Last Post: 01-17-2012, 01:31 PM
  4. Will the Samsung Epic 4G battery fit the Samsung Nexus S?
    By KillerQ in forum Sprint Nexus S 4G Accessories
    Last Post: 09-06-2011, 01:30 PM
  5. The so called "Web Cam?"
    By RealFnCool in forum Motorola Xoom
    Last Post: 03-21-2011, 07:10 PM
