Suprabh Bajpai
I dont live in a village. I don't listen to audio book (and who is stopping you from getting earphones btw), and I have an AUX system in my car to help me with my GPS.
+1
This is one of the few gripes I have about the phone. however, I just had a JVC stereo installed in my older accord, and I use the N4 with it over Bluetooth and the volume is just fine on that device. Where I do get a little frustrated is around the home where I've got some older computer style speaker set ups, with a 3.5mm plug, in different rooms. On those speakers, the volume--even on max--isnt high enough, and is actually rather low when compared to how loud they used to be with my iPhone. Hope its addressed in an update if possible.
You might living in village. In the city , you guys, it almost impossible to listen audio books or use navigation. Waiting for software fix!!!!
I'm wondering how legit these volume booster apps are, sounds like some people here dismiss them as an electronic placebo
I had the same problem most people in this thread have, and like most I looked at the various attempted solutions and had just about given up. I actually found the solution in my case while playing with NFC Task Launcher out of curiosity. I'd decided to have a play with NFC tags so installed NFC Task Launcher. Creating my first tag I selected sound and volume and checked media volume and system volume and hit next. I set both to max. System showed as 7 and media as an underlined exclamation mark. I then hit the right arrow and then the top right tick mark to save. I didn't actually have any tags to write but found the menu lets you run them without a tag. After running the sound from aux out was excellent. I can now hear my sat nav instructions very loud and music too loud even for me, and I am hearing impaired!. Tickled pink!
Hope this helps someone else.
