Page 1 of 3 123 LastLast
Results 1 to 25 of 75
Like Tree3Likes
    BobbyTheNinja's Avatar
    Posts
    ROM
    Stock Yakju 4.1.1
    Default Nexus 4 low AUX volume temporary fix?
    The Nexus 4 outputs much lower volume through AUX than the Galaxy Nexus (although the Nexus 4's Speaker volume is just fine and loud). I always use the AUX on the phone and listen to music in my car. At max volume, the Nexus 4 is nowhere near the Galaxy Nexus' max volume. I put my car on its max volume and it isn't loud enough on the Nexus 4. I have looked everywhere for a temporary fix but can't find any (hopefully Google eventually fixes this in the next software update). Anyone know of any? I have tried several volume boosting apps and they don't work on the Nexus 4.
    Thanked by:
  2. #2
    Default Re: Nexus 4 low AUX volume temporary fix?
    Same issue I have. My old iPhone 4 is around double the volume, hopefully it can be fixed by software and not a hardware issue.
  3. #3
    I'm pretty sure there's a setting for "safe headset volume". Try finding that and turning it off.
  4. #4
    I'm having the same issue, it's not terrible but it's not nearly as loud as my old iPhone. Also I couldn't find any "safe volume" setting
  5. #5
    bobjohnson201's Avatar
    Posts
    ROM
    Stock
    Quote Originally Posted by FYourProblems View Post
    i thought it was somewhat quieter than my galaxy s but i just shrugged it off. will check again and report back.
    Kyocera Marbl >> Kyocera Slider Sonic >> Sony Ericsson W580i >> LG Envy Touch >> Samsung Epic 4G >> LG Nexus 4
    Thanked by:
  6. #6
    Also I don't mean to highjack the thread but do you guys notice how the auxillary port is a little crooked? When you plug in headphones or anything it's not straight but slightly tilted to the left... or is that just mine? I've been a little paranoid it's just my phone
  7. #7
    Something is off. My Foxl external speakers which worked fine with the GNex can't make a proper connection using the aux jack in the N4. Aaargggh.
    Thanked by:
  8. #8
    Posts
    ROM
    Stock
    yea it is slightly to the left but i mean its just the design
    Thanked by:
    FYourProblems likes this.
  9. #9
    Try using poweramp is a music player as well as an equalizer.. Very good at that as well..
  10. #10
    Quote Originally Posted by bobjohnson201 View Post
    Thanks for confirming, I just wanted to make sure it's not me
  11. #11
    you have to plug in your charger. once you have your charger plugged in it will be loud.....but will have alot of static. i think im gonna buy a special shielded cable Aux cable. Amazon.com: Kensington Noise Reducing Car Audio AUX Cable for MP3 or SmartPhone, including iPhone 4S: MP3 Players & Accessories
    or a bluetooth kit
    kinda dont like the fact that i have to buy something to make my phone work, but i have faith google will acknowledge issues and dosomething about it
  12. #12
    Quote Originally Posted by techlover757 View Post
    or a bluetooth kit
    I've played it plugged in and not and on my phone it makes no difference. This is the only issue I'm having with this phone I hope it's a software thing
  13. #13
    Posts
    ROM
    Stock
    haha no problem
  14. #14
    Posts
    ROM
    Stock
    alright guys, here's what i did. I used the same music player, and was switching between the same song on my n4 and my galaxy s with my klipsch x10 headphones. First I checked how many times I need to press the "up" button to get to max volume. It was 15 times for both phones. I compared volume levels on both after pushing the "up" button 7 times from no volume. I found the galaxy s to be louder. I pushed the volume up button again on the n4 (so 8 times up from no volume) and it's exactly the same volume as the galaxy s (7 times up from no volume). I'm assuming plugging into a car would mimic the same scenario, so not a big deal for me.
  15. Thread Author  Thread Author    #15
    Posts
    ROM
    Stock Yakju 4.1.1
    Accidentally deleted my other post... Lol wow. Well plugging in the charger barely makes a difference and neither does the Bluetooth kit.
  16. Thread Author  Thread Author    #16
    Posts
    ROM
    Stock Yakju 4.1.1
    What music player did you use? The Google Play Music default one?
  17. #17
    Posts
    ROM
    Stock
    Quote Originally Posted by BobbyTheNinja View Post
    I used "PlayerPro" and was listening to a Breaking Benjamin track
  18. #18
    The volume on this phone sucks for sure, compared to my nexus 7 and Evo. I would have to think this is a hardware issue since the Nexus 7 has the same software. I'm extremely unhappy about this as I listen to a ton of podcast. Playing the same podcast (using doggCatcher) on all three on my home stereo, the Evo and Nexus 7 have very similar results and the Nexus 4 is extremely lower.
  19. Thread Author  Thread Author    #19
    Posts
    ROM
    Stock Yakju 4.1.1
    Now I see what you're saying. My problem is that at max volume, the Nexus 4 isn't nearly as loud as most other phones. I have to put the volume of my car radio at its max. I never had to do that with the Galaxy Nexus and it was still much louder. Unfortunately there isn't a volume booster app that works yet on the Nexus 4 that I know about.
  20. #20
    Posts
    ROM
    Stock
    hmm well I use playerpro in the car too so the point of my test was to see how the volume compares to my previous phone while using headphones, and i found that they were exactly the same when the n4 was raised one volume level higher. so in the car I would assume like a car radio volume level of 17 with my old phone will be the same as a car radio volume level of 20 with the n4.
  21. #21
    Some songs are louder than others but I regularly have to put the phone and the car stereo up all the way, and even then I'd like it a little louder.
  22. #22
    Posts
    ROM
    Stock
    do the test i did and see if your results are in accordance with mine.
  23. #23
    Posts
    ROM
    Stock
    what about with headphones?
  24. #24
    Exergy's Avatar
    Posts
    Global Posts
    473 Global Posts
    I haven't noticed any issues.
    Blackberry Bold 9000 > Google Nexus One > Samsung Captivate > iPhone 4 > iPhone4s ... Nexus 4
  25. Thread Author  Thread Author    #25
    Posts
    ROM
    Stock Yakju 4.1.1
    Ok I did your test with headphones. It seems like between volume levels 12/13 (out of 15) on the Galaxy Nexus matches the Nexus 4's maxed out 15/15 volume.
    Thanked by:
  1. Low speaker volume on Galaxy Nexus
    By Sriman in forum Google / Samsung Galaxy Nexus
    Last Post: 10-27-2012, 01:07 AM
  2. Good news about low speaker volume
    By CBCstillmatic in forum Motorola Droid X
    Last Post: 09-23-2010, 08:43 AM
  3. Low earpice volume fix...
    By ConceptVBS in forum T-Mobile Vibrant
    Last Post: 09-12-2010, 02:12 PM
  4. Low initial volume when powering up Bluetooth
    By Amphicar in forum Motorola Droid
    Last Post: 03-03-2010, 11:20 AM
  5. How's the Nexus One's Volume???
    By briankeith513 in forum Google / HTC Nexus One
    Last Post: 02-16-2010, 04:46 PM
