- 12-14-2012, 11:20 PM
Thread Author #1
Anyone else experiencing flaky/unreliable USB connection to PC on their Nexus 4?
Has anyone else been experiencing the following USB connection problems with their Nexus 4?
Whenever I connect the phone to either of my Windows 7 PCs via the supplied USB cable, one of the following things will happen:
- Nothing happens...no "Connected as a media device" message pops up on the phone, and Windows doesn't make the usual USB-connected "double bonk" sound. The phone does not show up in "My Computer"
- The "Connected as a media device" message will show up on the phone, Windows will make the USB-connected "double bonk" sound immediately followed by the USB-disconnected "double bonk" sound. Again, the phone does not show up in "My Computer"
- The "Connected as a media device" message will show up on the phone, but Windows will show a "USB device not recognized" message and doesn't properly load the drivers.
- Everything occurs as it should...all the usual USB-connected sounds and message, proper drivers, and the phone shows up in "My Computer"
Note that in all of the above cases, the phone will always charge properly when the USB cable is plugged in, regardless of the USB connection status.
I am using the USB cable that came with the phone, and I've tried every USB hub, port, etc that I have. All show the same flakiness.
I am suspecting that there might be an issue with the USB cable or the USB micro-b port on the phone because I've noticed that I can get the connection to come and go away just by applying very light force and/or wiggle to the micro-b connector when it is plugged into the port on the bottom of phone.
I've searched on many forums and haven't been able to find a single reported incident of this from anyone else with the Nexus 4, but I have read a few similar issues with other Android devices. I've tried the solutions posted (reboot phone, toggle between MTP and PTP transfer modes, etc.) but none of them make a difference in my case.
Any feedback is greatly appreciated, even if it's just to say "I've never had any problems with USB on my phone. It's always rock solid."
Thanks - 12-15-2012, 02:02 AM #2
Re: Anyone else experiencing flaky/unreliable USB connection to PC on their Nexus 4?
I have not had this problem.
Is your phone in a case? I have found that the USB port cutout in my iBlason tpu case interferes with some of my many different USB cables, making it difficult to fully seat the connector. - 12-15-2012, 02:31 AM #3
I too am having this exact issue... Definitely strange especially considering the phone continues to charge no matter what. I was suspecting the cable to be malfunctioning too, but haven't had a chance to try a different one. And no, I don't have a case.
- 12-15-2012, 09:28 AM #4
- 12-15-2012, 07:20 PM
Thread Author #5
- 12-15-2012, 07:30 PM #6
I am having the exact same problem. I am running Windows 8 and have to keep unplugging the usb cable and plug it back in. Eventually it will work.
Sent from my Nexus 4 using Tapatalk 2 - 12-18-2012, 11:43 AM #7
Hey,
my PC won't recognize the Nexus 4 at all. No plong sound, nothing.. But, as you reported, it charges as expected.
It really sucks right now because I need to get access to a file on the device.. :/ - 12-18-2012, 12:28 PM #8
- 12-18-2012, 01:21 PM #9
Try a different port or reinstal the drivers that it installed in the first place.
- 12-18-2012, 03:07 PM #10
Try a different cable?
Sent from my Nexus 4 using Android Central Forums - 12-21-2012, 10:36 AM
Thread Author #11
Just wanted to post an update and a solution.
I discovered that sometimes when I thought the phone was charging it actually wasn't. The lock/home screen would say "charging", and the little lightning bolt would show up on the battery icon, but if I went into the battery settings, it would say "not charging". Also, the battery charge percentage would not increase. The only way it would reliably charge through USB was if I actually got Windows to recognize the device correctly (i.e. got it to show up in "My Computer").
I went out and bought a new USB cable and haven't had any problems since. The device is correctly recognized on every USB port I've tried (my USB hub, front case connector, back of motherboard, and on my laptop). Funny since the Nexus 4 manual says to use only the supplied cable.
Hope this helps others who are having this problem. - 12-22-2012, 10:37 PM #12
I'm using Windows 7. When I plug it in to any of the USB ports it shows up as the "Nexus 4" in My Computer, but when you click on it, you don't see any of the file structure. I basically can't transfer any files to it.
It did work one time, but has not ever since. I have tried it in multiple USB ports on my computer.
As an odd aside, I'm also having issues with wireless transfer with WINAMP. It initially recognized the device and was doing transfers, but now does not recognize it. Anyone have any thoughts? I have reconfirmed that both are operating on the same wireless network. Don't know why they are not connecting. - 12-23-2012, 07:34 AM #13
- 01-06-2013, 06:39 PM #14
I'm experiencing following: whatever I connect my phone to computer I can hear the sound: connected device. After half second I hear the sound: device was disconnected. Phone being in charging state. But charging picture is blinking like if you constantly connect to adapter and disconnect it right after. I suspect new version of nexus 4. Therefore I want to try to downgrade back to 4.1 and I have no idea how to do it!
- 01-25-2013, 08:36 AM #15
I have the same problem. I've tried to use 3 different cables and nothing changed. PC doesn't recognize the device, there's no any sound when I connect the phone to USB-ports. Did anyone solve the problem??
- 01-25-2013, 09:27 AM #16
- 01-25-2013, 09:45 AM #17
- 01-26-2013, 02:14 AM #18
- 01-26-2013, 05:26 AM #19
- 01-28-2013, 06:01 AM #20
i have the nexus gt19250 by google and i canot sync it with my pc ... i am using kies program for samsung !! i called samsung and they told me that google nexus IS NOT WORKING with kies program for samsung cz google never asked for it ... does anyone knows another software for windows7 to sync my phone ??
- 01-28-2013, 10:55 PM #21
It's dead. Got it to LG repair service, there is a problem with a charger scheme. The scheme burned... They said it can be repaired, but I have to wait till they buy the scheme
Wait about 1 month... Problem with PC connection is the same as they said.
I charged N4 twice before, not from original charger, but from charger that worked and works fine with all of my other devices.
They took a photo, but I don't understand where is the problem on it. Attached it. - 01-30-2013, 11:35 AM #22
So are there any clear signs if this so-called "charger scheme" is burned out? Currently my Nexus is unable to be recognized by the XP machines at work and Win7 Machine at home. I cannot charge it via USB connection to either PC even though it shows the battery charging icon on the phone. I also cannot manually install drivers for Nexus 4 because windows deem the drivers incompatible with the device connected (it doesn't even recognize it as a phone?).
- 02-15-2013, 09:40 AM #23
- 02-15-2013, 10:19 AM #24
Since the update to 4.2.2, I noticed that my Windows 8 Pro doesn't detect my phone under My Computer. On the phone itself, it is charging through the USB but it's not detected as a device that's plugged into my PC. I've went through 3 different cables and tested on both front and back USB ports of my PC but the problem still persists.
- 02-15-2013, 12:08 PM #25
Unable to connect to Wifi on new Nexus 7 tablet
By easbury6 in forum Google Nexus 7 TabletReplies: 9Last Post: 12-25-2012, 06:46 AM -
Anyone else having problems getting video files to play on TF-101
By taalibeen in forum ASUS EeePad TransformerReplies: 6Last Post: 11-26-2011, 05:53 AM -
Evo to PC (Connect to PC via USB) problem fix
By Jerzyiroc in forum HTC EVO 4GReplies: 1Last Post: 07-16-2010, 08:56 PM -
USB connected to a corporate PC
By intrloper in forum Motorola DroidReplies: 4Last Post: 05-11-2010, 01:23 AM -
Anyone else experiencing random reboots lately?
By CavemanOOGA in forum Motorola DroidReplies: 13Last Post: 02-18-2010, 08:26 PM
Reply
