- 12-17-2012, 10:51 AM
Thread Author #1
Battery Issue - Android OS draining battery
Hello all,
this is my first post here. at some point my android os became the #1 battery drainer on my nexus 4 and i'm not sure why or
if its the way its supposed to be.
below are screenshots.
i have a live wallpaper (galactic core), could that be the reason for 34%??
thanks! - 12-17-2012, 12:48 PM #2
- 12-17-2012, 01:11 PM
Thread Author #3
- 12-17-2012, 02:37 PM #4
Re: Battery Issue - Android OS draining battery
I also have high Android OS, although not higher than the screen. But it's on 2nd place, where with my GNex on 4.2.1, it's normally on 4th place or lower.
- 12-17-2012, 02:40 PM #5
- 12-17-2012, 03:10 PM
Thread Author #6
yeah im not complaining generally about battery time - just specifically on this percentage, since about 2 days ago the android os was some single digit percent, and suddenly it jumped to this, so i keep thinking i did something to mess it up.
i have since set wifi to off when in standby, i guess ill see if that helps only later on. - 12-17-2012, 03:18 PM #7
- 12-17-2012, 04:04 PM
Thread Author #8
- 12-17-2012, 04:50 PM #9
- 01-11-2013, 01:26 PM #10
- 01-11-2013, 03:17 PM #11
- 01-11-2013, 06:29 PM #12
- 01-12-2013, 09:13 PM #13
- 01-13-2013, 01:24 AM #14
Shut off "Google now" I'm telling you. Its increased my Battery by A LOT..
Sent from my Nexus 4 using Android Central Forums - 02-03-2013, 10:36 AM #15
Mine has been 20-24% lately. Google needs to fix this ASAP
- 03-04-2013, 05:13 PM #16
i experienced this too. my nexus 7 is 92% charged then i woke up after 7 hrs, my nexus 7 is asleep then it went down to 74%. - 03-04-2013, 10:09 PM #17Nexus 4 on the Solavei network.
- 03-04-2013, 10:23 PM #18
- 03-05-2013, 02:59 AM #19
- 03-05-2013, 09:24 AM #20
Not sure what's going on with mine. Took it off the charger at 6 am put it in my pocket and drove to work. Looked at it at 7:30 and the battery had drained to 92% and the battery indicator showed it was still attached to the charger. Android OS is the big drainer.
And check out the charge activity between 4 and 5 while it was on the charger and I was asleep.
Sent from my Nexus 4 using Android Central Forums - 03-06-2013, 07:14 AM #21
- 03-18-2013, 08:30 PM #22
- 03-21-2013, 10:33 AM #23
Google+ App draining battery
By gsweinberg in forum HTC One XReplies: 10Last Post: 01-05-2013, 12:24 PM -
Google Voice draining battery.
By Jalarm in forum T-Mobile Nexus SReplies: 3Last Post: 01-30-2011, 04:48 PM -
Google Voice and Battery Drain
By corinthians in forum Sprint Epic 4GReplies: 8Last Post: 01-21-2011, 04:34 PM -
Google Voice draining battery?
By void.pointer in forum AT&T CaptivateReplies: 0Last Post: 09-21-2010, 01:27 PM -
Android OS draining battery??
By lmac00 in forum Motorola DroidReplies: 9Last Post: 05-20-2010, 07:50 AM
Reply
