- 12-17-2012, 08:37 PM
Thread Author #1
nexus 4 GPS problem? or does google maps not work with gps offline?
i just downloaded new york city offline map with google maps. and now i turn it on without the wifi and i've enabled gps but it can seem to track my location. i've left it for 30 mins and still nothing. is this a problem with my nexus 4 GPS or does google maps not work with GPS in offline mode?
- 12-17-2012, 09:12 PM #2
Re: nexus 4 GPS problem? or does google maps not work with gps offline?
google maps navigation(gps) dont work offline. you need to have data for navigation. when you try to navigate it give a message asking to enable data/wifi. you might have checked "Never show this message again" in the past.
one good thing about offline map is it save you a lot of data while using gps. - 12-17-2012, 09:41 PM
Thread Author #3
that's good news and bad news lol. good news, gps is not broken. bad news, google offline don't work lol. i used citymaps2go on the iphone and it's amazing, however, on android, that app is so poorly coded and it lags badly even in nexus 4. thus i use google maps offline, but only to find out that gps don't work offline...
- 12-17-2012, 09:46 PM #4
- 12-17-2012, 10:08 PM #5
i havent had any issues with google maps. The only GPS issue i have is when I try to use the speed test app it always thinks im in Texas or Kansas. (I'm in California)
Anyone else experience this? - 12-17-2012, 10:34 PM #6
Yeah... gps uses data. Ever wonder how the gps knows where you are? By the system sending a signal to a satelite to where you are so yeah.. you need data.
Google offline works, there is no issue with it. The reason you get it is to see the area around and where places are.
GPS NEVER WORKS OFFLINE - 12-17-2012, 10:42 PM
Thread Author #7
what? gps sends data yes, but it's not using your data plan. it's not the same data that that is used to to browse internet you know? there is no reason for gps not to work without data plan, you make no sense....
also i can use gps offline with citymaps2go...no data needed... - 12-17-2012, 10:59 PM #8
- 12-17-2012, 11:07 PM #9
meant that it doesn't work with a connection to anything. If you don't allow it to send data to the satellite, it can't pick up your location and if you disable all transmittions you won't allow it to send data. Another clarification is that the GPS doesn't work well because it can't send data accurately with cell towers.
- 12-17-2012, 11:11 PM
Thread Author #10
you can shut off every type of data and but as long as you have the gps receiver on, it will work.... again mobile data has nothing to do with gps. car gps has been doing this for while. there are small third party bluetooth gps adapters for ipod touch that has been doing this for a while. i can keep going on...
- 12-17-2012, 11:47 PM #11
GPS doesn't have to transmit anything to a satellite. It's strictly a matter of receiving transmissions from the satellite.
question for the original poster: are you trying to navigate or just have the map open up and show you your location? With offline maps you should see where you are, you just can't get turn by turn directions.
Sent from my Nexus 4 using Android Central Forums - 12-17-2012, 11:56 PM #12
- 12-18-2012, 12:05 AM #13
- 12-18-2012, 07:16 AM #14
I downloaded an offline map that covers the area from my home to my place of work 20 miles away, then put the Nexus 4 into airplane mode.
Went out my front door, got into the car, plugged the phone into the charger. Started Google maps and cancelled out of the request to turn on a data connection, then loaded my offline map. The small blue arrow immediately showed my current location on the map.
As I drove to work, the blue arrow accurately tracked my position on the map. One thing I did notice: with a "live" map, the map automatically moves such that the blue arrow remains in the middle of the screen. However with the offline map, the map remains stationary while the blue arrow moves, eventually moving all the way off screen. At that point, I can either drag the map into position or tap the icon at the top right of the screen to automatically move the arrow back to center screen and center the map. During all this time, the GPS icon was present at the top left of the notification bar.
jinjin12, are you in Manhattan? If so, how does the GPS work for you with "live" maps? I only get to Manhattan a couple of times per year, so haven't experimented much. But, my sense is that GPS would not work very well because the tall buildings would limit the device to only seeing satellites which are more or less directly overhead; not enough to establish a fix in most cases. Can anyone comment on this? - 12-18-2012, 07:27 AM #15
Several people have already gotten this right, but just to add:
GPS and Google maps will work just fine without data. What you will NOT be able to do is search for things (like a coffee shop near your location) or ask for directions. But the map should load (if you've saved an area for offline use) and the GPS should show your current location.
On the other hand, you might be having trouble getting a direct line to a satellite, which isn't really a phone failure so much as a limitation of GPS. - 12-18-2012, 09:05 AM #16
- 12-18-2012, 09:14 AM
Thread Author #17
- 12-18-2012, 09:25 AM #18
- 12-18-2012, 09:32 AM #19
It's notoriously difficult to get a good GPS lock in the canyons of Manhattan, you never have a really good view of enough sky.
Try turning your Wi-Fi on and enabling Wi-Fi location. Even if you don't connect to a network, Google will have a surprisingly good lock on your location just by knowing what networks you're near.
Sent frm my Nexus 4 using Android Central Forums - 12-18-2012, 11:47 AM #20
Semper Fi
I love my LG Nexus 4! - 12-18-2012, 12:12 PM #21
- 12-18-2012, 01:00 PM #22
Open Maps. Tap Menu -> Make available offline. Follow the directions to pan and zoom the map so that it entirely includes the area you will be driving in. Note how it estimates the storage space required as you make the map area larger or smaller.
Later, to use the offline map, tap "Maps" at the top left of the screen, select My Places, and then the "OFFLINE" tab at top left.Thanked by: - 12-18-2012, 01:20 PM #23Semper Fi
I love my LG Nexus 4! - 12-18-2012, 01:28 PM #24
So far as I know, the actual "navigation" (planning the trip, rerouting when you miss a turn, etc) is performed by Google's (or TeleNav's, or ...) servers and so you must have a data connection for navigation to work.
Thanked by: - 12-18-2012, 01:50 PM #25
As an alternative, I have the free app ForeverMap2 which comes with one country's maps for free. You can elect to not download any of the states you don't think you'll need to save space. I'm pretty sure that it lets you use turn by turn navigation without a data connection, but I haven't tried it out on the road yet.
Semper Fi
Google voice not working with my sprint phone
By j8lacy in forum General Help and How ToReplies: 1Last Post: 03-23-2012, 06:57 AM -
Urgent: Google Maps not working!
By jrmarinojr in forum Verizon HTC ThunderboltReplies: 16Last Post: 03-21-2011, 09:16 PM -
Indoor Fascinate GPS testing (via Google Maps)- not good
By doctorPDA in forum Verizon FascinateReplies: 24Last Post: 09-13-2010, 08:27 PM -
Does the market not work with fresh?
By DocPeanut in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 7Last Post: 07-13-2010, 11:32 PM -
Gps/google maps not accurate
By ericatomars06 in forum Motorola DroidReplies: 2Last Post: 04-01-2010, 10:34 AM
Reply
