- 12-20-2012, 03:26 AM
Thread Author #1
- 12-20-2012, 03:45 AM #2
Re: Solution for Android OS being top battery user
I also found out (a while ago on my Nexus S so it may not apply to Nexus 4) that if you uncheck the "backup my data" and "automatic restore" options when you first sign into your account on your phone (as in initial set up) then this also really helps keep android OS under control. I've done this on my new Nexus 4 as well just in case. The downsides of course are if you've already set up your phone you'd need to wipe it and start again and also your apps wont automatically sync back down so you'd have to manually get the apps you want (personally I never trusted that process to get ALL the apps I like, its always been hit and miss for me). If you have Root and can do a Titanium backup (or whatever backup you like) then this process isnt as annoying but I, especially on my Nexus S really recommended it. Hope that helps someone if they're having the Android OS battery drain issue along with your recommendations of course.
- 12-20-2012, 04:57 AM #3
- 12-20-2012, 05:24 AM #4
I really want to know whether it works for all Android os.
If you want to know something about flash player go to this blog flash-video-player.blogspot.com - 12-20-2012, 02:55 PM
Thread Author #5
update: it has improved my battery life dramatically.
before the changes i was getting about 14 hrs max with 2.5 hrs of screen time, which isnt bad.
right now im on running 13 hrs with 1hr of screen time and the battery is only at 61%. - 12-20-2012, 03:08 PM #6
- 12-20-2012, 05:58 PM
Thread Author #7
- 12-20-2012, 07:58 PM #8"The Nexus 4 is such a big black slab of power that if you dropped it down in the middle of a pack of monkeys, they'd start using weapons." - Dirk Belligerent.
- 12-20-2012, 08:37 PM #9
- 01-05-2013, 08:19 AM #10
I'm on AOKP ROM i don't see the cell broadcast settings.
EDIT: is it safe to disable exchange services? i see it has something to do with email. - 01-05-2013, 08:33 AM #11
- 01-05-2013, 08:47 AM #12
- 01-05-2013, 11:25 AM
Thread Author #13
- 01-06-2013, 08:45 AM #14
- 01-06-2013, 11:56 AM #15
When exchange services are enabling, my battery drains at an alarming rate. See this thread. MS Exchange email client draining battery?
Anyone else track their battery drain back to exchange active sync? - 01-06-2013, 12:06 PM #16
- 01-06-2013, 01:14 PM #17
Solution for android.process.media force close
By bbetenson in forum T-Mobile G2Replies: 3Last Post: 04-25-2013, 02:35 PM -
android os killing my battery?
By miyanc in forum Verizon Galaxy NexusReplies: 5Last Post: 08-14-2012, 08:28 PM -
BlueMusic 3 for Android OS
By meda in forum General News & DiscussionReplies: 1Last Post: 12-10-2011, 08:42 PM -
VZ Navigator is now top battery user at 53%
By NormanGC in forum Motorola Droid 3Replies: 3Last Post: 07-28-2011, 11:29 AM -
Top battery users
By Droid800 in forum T-Mobile G2xReplies: 1Last Post: 05-09-2011, 07:12 AM
Reply
