Results 1 to 3 of 3
    damo's Avatar
    #teamandroid
    Posts
    Global Posts
    164 Global Posts
    Default Battery drain - Maps
    Can anyone shed any light on why maps is using so much of my battery? I've used it for literally 2 minutes and there was a lot of usage even before I used it.
    Thanks ☺
  2. #2
    Default Re: Battery drain - Maps
    Did you force close it from app switcher? And try clearing the cache. Pretty sure it shouldn't take that much battery even if you only used 30% of the phone so far.
    Thanked by:
    damo
  3. #3
    Open google maps-->menu(three dots)-->settings-->location settings-->Uncheck "Report from this device"
    give it a few days. it will come down.
    Thanked by:
    damo
  1. Maps and Battery Drain-Post Jellybean
    By dannyro77 in forum Verizon Galaxy Nexus
    Last Post: 05-04-2013, 12:50 AM
  2. [HOW TO]Google maps battery drain fix
    By MasterTec in forum Virgin Mobile Optimus V
    Last Post: 05-03-2013, 03:11 PM
  3. Major Battery Drain After Latest Google Maps Update?
    By jephanie in forum Verizon Galaxy Nexus
    Last Post: 08-26-2012, 10:28 AM
  4. HELP. Google Maps Battery Drain
    By vg7702 in forum Sprint Nexus S 4G
    Last Post: 12-21-2011, 12:29 PM
  5. Maps 5.8 - high battery drain
    By mrg666 in forum Android Applications
    Last Post: 08-01-2011, 08:38 PM
