Was just wondering if this has happened to anyone recently with their N4's. This has happened twice recently so I think I can officially call it a problem. My homescreen will lose its smoothness and actually lag A LOT. Opening folders, you can see every frame as if its slow motion. Moving the homescreens back and forth causes severe lag.
Also when it started happening, my phone went from 78% to 72% in about 60 seconds and continued to drain.
Possible Causes: To be honest, I have no clue. I was just simply sending a few texts and then it started happening. I forgot what I was doing the last time it happened. But, I wasn't running a lot of apps. I was doing anything RAM heavy for it to slow down so I really have no clue what it could be.
Methods I've tried to solve the problem: I looked at the apps running in the background, nothing seemed out of the ordinary but I stopped FB and Google magazines because those were consuming a lot of ram. I opened the multitasking window and swiped every app off. Both didn't work, only restarting the phone seems to solve the problem. Maybe i'll try uninstalling a few apps and see if that prevents it from happening again.
Looking at the battery stats, the only thing out of the ordinary was the increasing use by the Google Play Store. Dont know why.
Well, any thoughts on this guys? Anyone experience this before? Suggestions?
