Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By jonnie_r
  • 1 Post By still1
    6tr6tr's Avatar
    Posts
    Global Posts
    2,274 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Does Android's data usage "meter" differentiate between wifi and radio data?
    Now that I'm on TMobile's $30/month deal and there's a limit (5gb) of non-throttled data, I want to know when I get near that level. But it looks like the Android Data Usage in settings doesn't differentiate between data you download on wifi and data you do over cell radios. Is this right?
  2. #2
    jonnie_r's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Does Android's data usage "meter" differentiate between wifi and radio data?
    AFAIK the data usage tab only shows mobile data, i.e. carrier bandwidth usage, not WiFi.
    So you should be good to set your limits. I set my sons to shut off at 800mb even though he is on a 1gb plan.
    bobjohnson201 likes this.
  3. #3
    still1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, it does differentiate. by default you wont see wifi data usage you have to check a box in settings to see wifi usage.
    then you will see both in 2 tabs
    6tr6tr's Avatar
    Posts
    Global Posts
    2,274 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jonnie_r View Post
    I've heard this before but I wasn't sure since it also works on the Nexus 7 despite it being only wifi.
  5. #5
    still1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 6tr6tr View Post
    just to enable my above tip go to, settings-->data usage-->menu(three dots)-->show wifi usage
    6tr6tr likes this.
  6. #6
    Hubertsng's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah, what he said. I've noticed that i have had like 11 GB of data even though it's all wifi.
    6tr6tr's Avatar
    Posts
    Global Posts
    2,274 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by still1 View Post
    Thanks, I didn't see that before.
  8. #8
    still1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    glad i could help.
  9. #9
    severinj's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    my data usage will show about 4.2 to 4.4gb when tmobile sends me a text saying I've gone over my allotted 5gb limit.
    not sure why that is, but it's strange
  10. Thread Author  Thread Author    #10
    6tr6tr's Avatar
    Posts
    Global Posts
    2,274 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by severinj View Post
    Because the Android Data Usage, IIRC, shows the data that was sent/received by your phone's radios. Any data requested by your phone that was sent by TMobile but never reached your phone still counts against your actual usage.
  11. #11
    viper1025's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I dont see the menu in my SG3. And cant separate mobile from wifi. Any ideas.
  1. Data Usage- Does it include WiFi data?
    By mrshickadance9 in forum Samsung Galaxy S3
    Last Post: 12-24-2012, 01:42 AM
  2. Why does my SII measure weekly data usage versus monthly?
    By Tony Android in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 10-11-2012, 11:00 AM
  3. Android OS data Usage
    By dr_elusive in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 08-28-2012, 02:47 PM
  4. Replies: 7
    Last Post: 04-20-2012, 12:53 PM
  5. Does Android Central need more writers?
    By CNevius in forum Site Feedback & Help
    Last Post: 01-03-2010, 12:13 AM
