Results 1 to 4 of 4
    unknownx3's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Nexus 4 won't power up unless connected to charger
    So today when i woke up i unplugged my nexus 4 from the charger seeing how it was fully charged, it then suddenly turned off. I tried pushing the power button to see if it would turn on but no luck. I plugged the charger back onto the nexus 4 and i see that my LED for the nexus 4 started flashing red. It then showed the battery and i was able to turn it on, but when i unplug the charger it turns off again... Did anyone else experience this or was it just me? Should i call google to see if they can fix it or give me a replacement?
  2. #2
    Hubertsng's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Nexus 4 won't power up unless connected to charger
    That probably means that type battery had been dislocated from the power source or some thing
    Sent from my Nexus 4
  3. #3
    N4Newbie's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Are you rooted and using a custom ROM? I was reading on xda developer's site about a ROM which caused a similar problem...
  4. #4
    JoeSimms's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by unknownx3 View Post
    Same issue. Did you find a solution? Thanks...
  1. Flyer won't power up
    By djrakowski in forum HTC Flyer
    Last Post: 01-25-2013, 07:16 PM
  2. Nexus 7 will not start unless connected to mains charger
    By digitalix51 in forum Google Nexus 7 Tablet (2012)
    Last Post: 11-28-2012, 11:06 AM
  3. Want to root my phone but no USB access or won't power up.
    By bogey golfer in forum Motorola Droid X
    Last Post: 03-05-2012, 03:23 PM
  4. Verizon site pops up when connected to computer
    By alpha752 in forum Motorola Droid X
    Last Post: 11-28-2011, 01:23 AM
  5. Evo won't boot up...anyone want to try and figure this out?
    By FireFighterChen in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 03-02-2011, 07:10 PM
