Results 1 to 8 of 8
- 01-06-2013, 10:02 PM
Thread Author #1
Battery rub out quickly
Hi,
I just got my Nexus 4 couple days ago, I use it mostly as a phone ( from time to time I open chrome or check my emails), but I have to charge my phone many times a day. this is my first smartphone, do you think I am missing something or I don't know how to set it ?
thanks, your help is appreciated. - 01-06-2013, 10:11 PM #2
Re: Battery rub out quickly
The key is the words "this is my first smartphone".. Every smart phone has much worse battery life than a dumb phone. You will get used to it and your usage will become normalized after a while and require less charging. This phone is probably middle of the road for battery life when it comes to smartphones.
Sent from my Nexus 4 using Android Central Forums - 01-06-2013, 10:23 PM #3
You should expect 3 to 4 hours of screen time on a single charge.
You just need to learn to manage your battery - turn the screen brightness down, adjust apps so that they don't constantly connect to the internet to update themselves, etc. 2 out of every 3 threads here are about this very topic!
Sent from my Nexus 4 using Android Central Forums - 01-06-2013, 10:36 PM
Thread Author #4
The Quick Start guide is very poor, is there any other source on how to use this phone (Nexus 4), for example (because this is my first smartphone), when I have an apps or browser opened there is no exit, I just go to the home button link in the bottom then open another thing.
thanks - 01-06-2013, 11:21 PM #5
- 01-06-2013, 11:43 PM #6
^^ this.
Other things you can do to increase time between charges include
- turning off GPS and Bluetooth if you don't use them,
- running a 'normal' wallpaper instead of a live wallpaper,
- using WiFi where available over using the cellular radio (WiFi is far less of a drain),
- using fewer widgets,
- reducing the screen timeout threshold, and
- reducing the frequency with which it checks for new email.
Telling it that it looks pretty and sending it a digital bouquet once in a while wouldn't hurt either. - 01-07-2013, 05:39 AM #7
- 01-07-2013, 09:51 AM #8
You don't need to exit most apps, the OS does a good job of running them in the background and closing them when needed. If an app has the ability to exit, it will either be in the menu (look for the three dots) from the app's home screen, or you can try hitting the back button from the same screen and see if it asks you if you want to exit. Otherwise, you can go to the multitasking panel (the right-most button on the bottom of the phone) and swipe away any apps you want to exit. You shouldn't have to worry about doing so, however, as the phone will warn you if an app is running abnormally in the background.
Extended Battery sold out at VZW website
By chrisv79 in forum Bionic AccessoriesReplies: 2Last Post: 09-14-2011, 04:56 PM -
Extended battery drained SO quickly...why?
By SMD in forum Verizon HTC ThunderboltReplies: 51Last Post: 04-22-2011, 06:01 PM -
Battery Left Out In Rain
By AWDmonster in forum Incredible AccessoriesReplies: 0Last Post: 10-29-2010, 02:51 PM -
battery dieing to quick..
By giggalz in forum HTC Droid ErisReplies: 3Last Post: 09-04-2010, 11:58 AM -
Traveling With EVO (Bad Battery Life out of Home Market)
By Epsom_D2 in forum HTC EVO 4GReplies: 16Last Post: 07-14-2010, 05:50 PM
Reply
